avatar_GTX
Heinkel He-100 and He-112 Fighters
Started by GTX, December 15, 2007, 01:35:39 PM
HoOmAn
Quote from: apophenia on February 06, 2010, 01:26:43 PM
Extending the radiator bath (or going P-51 style) would also eliminate the possibility of a belly stores rack. If you're going for a larger engine, why not just stick with the late-model Spitfire wing radiators?
All true....
I eleminated the under wing radiators to avoid a look too close to a Spit. Probably wing root inlets would be an option?
Quote from: HoOmAn on February 06, 2010, 03:36:19 PM
Well, on the Alternate History board I gave a brief summary of the planes as used by the RSAF (see below). In it´s final appearance engine power has grown up to 1400hp. A larger radiator thus would make sense - as would under wing installations too, probably. What I never figured out is what kind of modifications could be expected to the cowling. Speaking of stream lining of cowling and canopy is one thing - drawing it.....
Fortunately, you don't need to figure it out: Heinkel did it for you..... ;D
Heinkel He.112 V10 with Db.601 engine:
This info from the Squadron/Signal book Heinkel He 112 in action, aircraft no.159, ISBN 0-89747-352-3. If you're interested in the He-112, this book is gold dust, and it isn't even expensive.
HoOmAn
Jesus, is that bird ugly!  :blink:
Will probably try and get that book....
I've been away for a couple of weeks. I *LIKE* the He-112 with Spit cropped wings and the original He-112 canopy. Dunno if you've already seen it, but I did one (He-113T) that is on the second-to-last page of this thread. It had a He-162 "bubble" canopy, a Mustang (narrowed) under-fuselage radiator, and Spit 22 wings (plus 4-bladed prop).
I really do like the fuselage look of the He-112. The engine was the Jumo 210, I believe, and might need an upgrade. My upcoming He-100/113 will end up having a "Nanzan" nose and radiator setup to fill the bill.
Haven't visited this thread in a long while. Since then, I have indeed succumbed to "He-100 fever" and made a "He-113" to my liking. The build thread is at:
http://www.whatifmodelers.com/index.php/topic,26949.0.html
But I will post a pic here that shows my scaled up "113" version in desert livery alongside a more-or-less "stock" He-100 that I did as a carrier fighter:
The front canopy looks like it was taken from a Blackburn Skua! I suspect that the central pylon was made from the Lindberg "display stand"!!
Still, *ANY* He-100 derivative will catch my eye!
Pablo1965
Well, the canopy came from a Boulton Paul Defiant but vacuformed by me, The central float came from a Smer Macchi S79 cloned in resin. The union with the float came from a 1/600 New Ray base of a plane.
Looks to me like it needs more bracing.  That central strut looks like it would snap on the first heavy landing.  Very graceful, I'll grant you but a bit too spindly for my likes.   Otherwise an interesting model.  :thumbsup:
Pablo1965
Quote from: rickshaw on September 17, 2011, 07:16:46 PM
You are right, I have sacrificed all logic to find a very specific aesthetic, but it's my way of doing things and never get what I want, I just settle.
Heinkel He-100 as a real fighter (not a record plane) with conventional radiators.
KJ_Lesnick
For a laminar flow airfoil like the P-51's, which planform would be better from an aerodynamic standpoint: The Heinkel He-112 or the Supermarine Spitfire?
Default Setting
Didn't the He-112 require significantly more man-hours to build than the Me-109? In which case it might be a trade-off between quality and quantity.
The one duty we owe to history is to rewrite it.
-- Oscar Wilde
Reengining He-112
EDIT: fixed bulges
