avatar_Archibald
Aermacchi M-346
Started by Archibald, February 12, 2007, 02:13:28 AM
And dont forget the 1/72 KP one! :wub:  :wub:  :wub:
Honestly, ive been looking for the eduard kit every time ive been in the shop, however i only find the KP kit... :(
another whiff potential would be a Carrier based varaint to replace the Skyhawk.
countries that would buy it would be:
-Netherlands: for multirole use on the CVF "Karel Doorman II"
-Brasil: to replace the A-4KU.
-Canada: you know why, nuff said  B)
PanzerWulff
Whats the Mako look like???? :huh:  :huh:  :huh:
PS The first one of you Clowns to post a pic of a shark gets 1000 lashes with a wet noodle ARRRRRR :ar:  :P  :lol:
Archibald
elmayerle
QuoteAmodel do a 1/72 kit of the Yak-130, which was the basis for the M-346:
Where can I see the differences between M-346 and Yak-130?
The Yak has a shorter sharp nose, and stealthy air intakes. Engine exhausts are placed further in front. Also has wingtip missie rails and canopy is slightly different. Vertical stabilizor is shorter than the italian (by just a little), and the Yak uses up to 100 meters more than M-346 (380 meters for Yak-130, 280 meters for M-346)
Not to mention a difference in engines, too.
--Jane Wagner and Lily Tomlin
Yes, but I meant VISUALY. In order to build a M-346 from a Yak-130 model, which is easy to get.
Thanks,
Carlos.
