avatar_GTX
Is There A Kit Or Conversion Available
Started by GTX, March 09, 2007, 02:33:21 PM
Hi folks,
Is there a kit or conversion available of the either the F-16F (Block 60):
or the Block 52 F-16C:
Preferably in 1/48.
Gervasius
I think you can build any Block 52 from one of these Hasegawa kits:
http://www.habu2.net/vipers/viperkits/48/hase48.4.html
Hasegawa single-seat vipers are available, while family model F-16s are OOP. Good luck finding one.
Baldrick: I followed Mr Da Vinci's instructions to the letter.
Blackadder: Even though you can't actually read.
Baldrick: No, but I have done a lot of Airfix models in my time.
Greg, CMK do a number of sets for F-16C/D's in 1/48.  The parts you'll need for a block 52 F-16C are probably in all four sets, it'll set you back a fair bit of cash.
http://www.hannants.co.uk/search/index.php...6&NUMPERPAGE=50
Jennings
Also check Isracast resin stuff.  He does a bunch of Israeli Lawn Dart stuff that should cross over to those you showed.
J
Jeffry Fontaine
#4
Meteor Productions has the conformal fuel tanks available under their Cutting Edge Brand Name.   CEC48428 "F-16 Saddle Tanks (Conformal Fuel Tanks)" for $13.99
Howard of Effingham
QuoteAlso check Isracast resin stuff.  He does a bunch of Israeli Lawn Dart stuff that should cross over to those you showed.
the latest issue of SAM has an article modifiying a cross between the RoG and Hase
F-16 kits using the 1/72 isracast F-16I sufa conversion set. the conformal tanks
look identical to me compared to those on the F-16E and F. the article is iirc by a
chap called yoam efrati and he is a fine modeller indeed.
trevor
Keeper of George the Cat.
