Question about fixed geometry intakes on supersonic jetfighter.
Started by aerofan, June 25, 2008, 02:08:26 PM
aerofan
Hope there are some aerodynamists or engineers out there who can answer this. As far as I know from materials that I've read, the fixed geometry 'D' type intakes can produce a perfect gas stream upto the mach 2.35 for a turbine engine to still operate effectively. My question is about the blended wing types, as in the Hawker Hunter, F-101 Voodoo, Skyray, etc. What is the highest mach number attainable for a perfect gas stream on these intakes?
KJ_Lesnick
How do you define a perfect gas stream?  Stable, or 100% inlet-efficiency?
In regards to blended intakes, at least pertaining to the Skyray and Voodoo, I don't think there actually is any major difference over a non blended design as the airplane at supersonic speeds (with it's intakes ahead of the wing, or wing-root) will not have the airflow into it affected in anyway by the airflow pattern over the wing.
In regards to the Hawker Hunter, it's got a blunt lip, which although swept looks like it would, at very low supersonic speed, form a shockwave on the root (which is also the fuselage side) which would keep the wave off the rest of the intake, but at mach numbers above that you'd probably get a strong shockwave which would just knock the speed right down to subsonic (normal shockwaves are very energy wasteful).  However to my knowledge the Hunter is only marginally supersonic (though I could be wrong) so I'm not sure how big a deal that is.
Kendra Lesnick
aerofan
Quote from: KJ_Lesnick on June 25, 2008, 02:29:20 PM
Kendra Lesnick
I would say stable so that the gas turbine engine will still operate properly. The only other blended wing design aircraft that I know of that has a maxium mach 2.0+ number is the F-105 Thunderchief. It quite interesting about the shockwaves as I believe that the air that enters the compressor of the turbine must be reduce to subsonic or else  the engine will stall. Thanks Kendra for the reply.
Mach 2.35 with fixed-geometry intakes? I thought it was around Mach 1.8. I don't have the reference to hand, but IIRC this was a factor in deciding the Hornet would have fixed-geometry intakes: it was felt the weight penalty was to great wrt the additional top speed.
Later Drakens and F-16s can do Mach 2 on fixed intakes. Although the Drakens superfically look "blended", in fact they're more like individual pitot intakes (like two F-100s, if you se what I mean).
