avatar_ChernayaAkula
AV-13 Dragonfly - a XV-15/AH-1/64/propfan mash-up
Started by ChernayaAkula, July 11, 2009, 09:15:34 PM
Found this cool beast while looking for contra-rotating props:
To me, it looks like a combination of an XV-15 and an AH-1 or AH-64, with some bits and pieces thrown on. Really like changing the big rotors for a propfan-ish arrangement. :thumbsup:
Would this type of propeller work instead of a rotor? :unsure: Looks cool any way. :wacko: Two six-bladed counter-rotating props. Wow!
Aircav
Sir Sydney Camm
Vertical Airscrew SIG Leader
I'm still confused by that propeller design. The prop blades seem rather long, but would they be long enough to support a vertical lift-off? Or would at least angling up the engine nacelles shorten take-off distance?
Well small props need to turn faster to generate the same thrust as large, slow ones, so if you put enough power through those props they WILL provide lift-off, but the downwash will be much more energetic. It'll be halfway between a helicopter and a Harrier, I imagine.....
Ok, this is incredibly cool, awsome and sexy looking, but - there's always a but isn't there?? - I see it working better as a fixed wing machine rather that a tilt rotor. As has been stated already the props look too small to give enough thrust to lift vertically. Well, thats my two penneth anyway.
Shasper
The Propfans would work just as well as the old proters, good news is if needed to you can perform a standard rolling takeoff instead of STO or VTO. Down side is the amount of propwash being put out (A Propfan is similar to the standard high by-pass turbofan, just without the engine ducting), and the noise level.
Shas 8)
- Bud S.
