avatar_Doc Yo
Did anyone make a B&V 155 in VAC ( 1/48>)
Started by Doc Yo, December 14, 2009, 12:41:17 PM
Doc Yo
  I just finished a sort of Maschinen Kreiger whif, the  Adler , and while I'm mostly satisfied, I
liked the design enough that I'm tempted to give it a try in a larger format. This is the old Airmodel kit
fused with an even older Frog Stuka, but both are in 1/72 ( scale-o-rama'd to 1/144 ) so if I can find
the major compnent, the B&V 155, in a larger scale, I'm pretty sure I can find a Ju 87 to match it.
I know there is a B&V 155 in 1/48 in resin, but I'd rather get a vac kit if one exists...
Doesn't seem to be Doc, my book says two companies make a resin 1/48 kit of it, Arba and MTS Models, Airmodel does a vac in 1/72 though,
http://www.airmodel.de/shope/shope.html
as does KPM and Wings (WK Models).  Pegasus does a 1/72 injection kit, you should drop Colin of Freightdogs a line, he has all the Pegasus moulds now.
CAO 700
I don't know vacu kits of the B&V 155. I just know these kits:
Special Hobby (plastic) 1/72:
RS Models (resin) 1/72:
Beautiful planes are french! (Amiot 143, for example...ugh!)
Doc Yo
 Thanks for the feedback. I did a little looking myself, but it seems I'll have to DIY most of it...
