avatar_jonas
Tutorial for photos and Photoshop
Started by jonas, October 13, 2010, 06:52:01 AM
jonas
Hi everybody
I need some help. I have lot´s of complete "What if" planes built by me, but I need a tutorial of how to take pictures from my planes (backgrounds used, lights) and how to use the photoshop to create images of the plane flying and fighting.
I don´t use kits to make my planes... I use another material. This material allows me to build planes and "play" with them.
Thanks a lot
Jonas
PLEASE VISIT MY FLICKR ACCOUNT: http://www.flickr.com/photos/einon/
Do you want to see one of your creations in LEGO? Please ask me!
The easiest way to do that is by taking photos against a background that has one color. Maybe a large sheet of paper.
When you open the photo in e.g, Photoshop, there's a function called 'Grow selection' or 'Select similar'. Check the details in the manual. Use this function to select the entire background, and delete this. What's left is the aircraft, which can then easily be pasted onto another photo.
saintkatanalegacy
hmmm... you could use a background that contrasts well with the plane...
you also need to have a fairly consistent lighting so the background is even...
select a background
take a photo and open and use it as a different layer
use the magic wand select tool and adjust the tolerance accordingly...
use the smooth the edges of the layer
voila! <_<
hope that helps
-ivy
Ivylicious!™
