Swept wing Hercules suggestions needed
Started by tigercat, June 19, 2011, 08:18:17 AM
tigercat
I'm planning on giving a C130 swept wings and need some assistance in suggestions for donors of appropriate wings. I'm currently thinking scaleoraming  1/144 airliner wings but don't want to buy a kit if they won't fit or will be too small curently I'm thinking 747 or 767
I've got a set of 144 scale 747 wings in the stash; I'll measure them in a couple of days.
For a project I'm planning, I found that the Airbus A320 wing has about the same 'max-take-off' lift capability as the Transall C160 wing (might be a bit better actually)
albeback
Interesting concept! I presume your model is 1/72? The 747 in tiddler scale has a wingspan of 19". However, scaling them up to 1/72 would probably give you a model not too far short of the C-130s 132 ft span. In any case, the efficient high lift devices on the swept wing would presumably negate the possibly reduced span?
I LIKE this idea!!! Will you be using turboprops for your model or, will this be a pure jet powered aircraft?
tigercat
not decided yet  possibly keep the 747 engines if suitable or possibly give it engines like the Russian Bear although probably not contra prop
albeback
Quote from: tigercat on June 19, 2011, 10:20:47 AM
If I may make a suggestion here, how about the CFM-56 engine? These produce 24-25000 lbs thrust In fact, a pair of CFM -56s would probably provide more than enough power for a fully loaded Herc? If you can get hold a pair they'd probably fit under the 747 wings without too much bother?
The C-130's 132' 6" wingspan scales out to about 22" in 1/72, the span of a 1/144 747-400 is about 17.5" (earlier model 747s are around 16.25").
tigercat
Thanks everyone  ;D
so not too far off as to look out of place
