Westland Whirlwind
Started by KJ_Lesnick, August 26, 2012, 01:32:32 PM
KJ_Lesnick
Did the high cruciform tailplane configuration it had suffer pitch-up or deep-stall troubles?
No. The problems you are referring to does generally not affect relatively light and slow aircraft, which even a Whirlwind F.X with double Griffons must be catogorized as in comparison to the F-101 Voodoo, for instance. Even the Gloster Meteor worked very well with it's T-tail throughout the marks. As a matter of fact, the high tail actually improved landing characteristics as the stabilators were kept out of ground turbulence
/P (who actually is planning a Whirlwind F.2 with Merlins)
