Me-109 TL.1
Started by Fritz13, August 17, 2013, 05:13:46 AM
Fritz13
perttime
Ha!
I like your design!
Do you have a side view that shows the jet exhaust?
I wonder how German ground crews took the burning grass fields and/or melting asphalt  :lol:
Quote from: perttime on August 17, 2013, 05:28:57 AM
Or the burning/melting tail wheel? :-\
Nice plane! Agree I'd like to see a side-view, if you have one. :thumbsup:
Guy
Logan Hartke
Quote from: Old Wombat link=topic=37523.msg608377#msg608377 date=1376748722
/quote]
Yak-15 didn't have this problem, did it?
Logan
martinbayer
Quote from: Logan Hartke on August 17, 2013, 07:46:44 AM
/quote]
Logan
Initially it did, which is why it was changed to solid steel after the first trials: http://en.wikipedia.org/wiki/Yakovlev_Yak-15
Martin
I don't know, I'd have to look it up. :-\
(Pre-post edit) Apparently Martin does know & it did. Thanks, Martin! :thumbsup:
Guy
perttime
They also put some sort of a metal heatshield on the bottom of the Yak-15 rear fuselage. That isn't necessarily obvious on a painted aircraft.
Those mods also went into my Heston Adder, although I tried to make the heat shield visible...
