avatar_McColm
C-27 Spartan ideas
Started by McColm, May 12, 2017, 07:02:40 PM
The Alenia C-27J reminds me of the Fairchild Provider. With that in mind the possibilities for Whiffing begin to expand.
The usual;
Gunship
Maritime Patrol/Surveillance
Search and Rescue
Transport
Electronic Warfare- Command and Control
Are available in the real world, the gunship was built and evaluated by the USAF and plans for a multi-missions version for  Special Operations before budget cuts forced the disposal of the order came into effect.
The US Coast Guard fly the C-27.
I'm sure that the engines could be changed to TF-33's or CFM jets. Or a glider if you prefer.
An AEW variant resembling the An-74 MadCap or fit the Erieye .
A seaplane/float plane for special operations or Polar patrols with skis fitted.
I'm not too sure that a COD version would be too big but a mini-tanker might be better.
No doubt someone will try and stretch the fuselage.
The 1/72 Italeri kit is well detailed, there are plenty of C-130 photo etched and resin enhancement sets that can be used for your build.
If Alenia refitted the tail with a Hawkeye/Greyhound style tail, it might work.  Of course, the other problems are being able to withstand repeated cats and traps, saltwater corrosion, and the other myriad of NAVAIR problems.
C-2 Greyhound:
C-2A/A(R) Characteristics
Length: 56 ft 10 in (17.30 m)
Wingspan: 80 ft 7 in (24.60 m)
Height: 15 ft 10½ in (4.85 m)
Wing area: 700 ft² (65 m²)
Empty weight: 33,746 lb (15,310 kg)
Useful load: 20,608 lb (9,350 kg)
Loaded weight: 49,394 lb (22,405 kg)
Max. takeoff weight: 60,000 lb (24,655 kg)
Powerplant: 2 × Allison T56-A-425 turboprops, 4,600 shp (3,400 kW) each
C-27A/J Spartan
C-27A Characteristics:
Length: 22.70 m (74 ft 5½ in)
Wingspan: 28.70 m (94 ft 2 in)
Height: 9.80 m (32 ft 1¾ in)
Wing area: 82.0 m² (893 ft²)
Empty weight: 14,590 kg (32,165 lb)
Max. takeoff weight: 28,000 kg (61,730 lb)
Powerplant: 2 × General Electric T64-GE-P4D turboprop, 2,535 kW (3,400 shp) each
C-27J Characteristics
Length: 22.7 m (74 ft 6 in)
Wingspan: 28.7 m (94 ft 2 in)
Height: 9.64 m (31 ft 8 in)
Wing area: 82 m2 (880 sq ft)
Empty weight: 17,000 kg (37,479 lb)
Max takeoff weight: 30,500 kg (67,241 lb)
Max payload: 11,500 kg (25,353 lb) at MTOW[citation needed]
Powerplant: 2 × Rolls-Royce AE2100-D2A turboprop, 3,460 kW (4,640 hp) each
And, of course just to throw it into the mix:
C-123 Provider
C-123K Characteristics
Length: 76 ft, 3 in (23.25 m)
Wingspan: 110 ft, 0 in (33.53 m)
Height: 34 ft, 1 in (10.39 m)
Wing area: 1,223 ft² (113.7 m²)
Empty weight: 35,366 lb (16,042 kg)
Max. takeoff weight: 60,000 lb (27,215 kg)
Powerplant:
2 × General Electric J85-GE-17 turbojets, 2,850 lbf (13 kN) each
2 × Pratt & Whitney R-2800-99W "Double Wasp" 18-cylinder radial engines, 2,500 hp (1,865 kW) each
I came across the 1/72 Italeri No 1284
C-27J Spartan whilst looking for parts for my other started builds and wondered if you can fit the engines from the Airfix Lockheed S-3 Viking and the rotodome from the Hasegawa Grumman E-2 Grumman.
Yes you can, I'm not too sure if the designation would still be kept or changed to the EC-127 Spartacus.
