avatar_McColm
The replacement for the Royal Air Force C-130J's
Started by McColm, June 08, 2021, 10:11:37 AM
Yes folks the powers that be have once again decided to retire the whole of the Royal Air Force's C-130J  Hercules fleet and replace them with the larger Airbus A400M Atlas. This will cause a gap in Transport Command as they are bound to want something smaller than the Atlas,  along with STOL capabilities.
To a Whiffer this means something commercial although it could be turboprop or turbofaned or even a combination of the two. So something smaller than the Atlas but bigger than the BAe -146.
The thought of a four engined C-160 has been on my mind for quite a while and the Roden An-12 Cub kit although not the best model in 1/72 scale does have potential to be whiffed.
I'm sure more ideas will follow.
if they are looking for something smaller then an A400M, inthe same league as the BAe146, then the RAF should either go with the Airbus C295M or the Lockheed/Leonardo C-27J Spartan.
Leading Observer
LO
Would the venerable Beverley fill the bill?  Take off 750 yards, landing 300 yards (both approx)  max load 22 tons, ferry range 4000miles
For comparison  Andover T/O 650 yards, Landing 350 yards    max load  7 tons, ferry range 1500 miles
Of COURSE a Bev would fit the bill, but you'd re-generate the 'Crew Generation' problem.
That's the one where you have to sing on a complete family (or three...) for each crew to ensure there are enough qualified pilots still alive to land the thing at the end of any long range flight............
Scotaidh
Quote from: PR19_Kit on June 08, 2021, 10:17:21 PM
Oh, I dunno - seems to me a turboprop upgrade should speed things along quite well.  And, they could use all those suddenly surplus C-130J engines - RR engines, IIRC.  :)
Specifications (C-130J)
General characteristics
    Crew: 3 (two pilots, and one loadmaster are minimum crew)
    Capacity:
        92 passengers or
        64 airborne troops or
        6 pallets or
        74 litter patients with 5 medical personnel
        2–3 Humvees, or 1 LAV III (with turret removed) or an M113 armored personnel carrier
    Cargo bay length: 41 ft (12.50 m)
    Cargo bay width: 10 ft (3.05 m)
    Cargo bay height: 9 ft (2.74 m)
    Payload main: 42,000 lb (19,051 kg)
    Length: 97 ft 9 in (29.79 m)
    Wingspan: 132 ft 7 in (40.41 m)
    Height: 38 ft 10 in (11.84 m)
    Wing area: 1,745 sq ft (162.1 m2)
    Airfoil: root: NACA 64A318; tip: NACA 64A412[130]
    Empty weight: 75,562 lb (34,274 kg)
    Max takeoff weight: 155,000 lb (70,307 kg)
    Powerplant: 4 × Rolls-Royce AE 2100D3 turboprop engines, 4,637 shp (3,458 kW) each
    Propellers: 6-bladed Dowty R391 composite constant-speed fully-feathering reversible-pitch propellers
Performance
    Maximum speed: 362 kn (417 mph, 670 km/h)
    Cruise speed: 348 kn (400 mph, 644 km/h)
    Range: 1,800 nmi (2,100 mi, 3,300 km) at max normal payload (34,000 lb (15,422 kg))
    Service ceiling: 28,000 ft (8,500 m) with 42,000 lb (19,051 kg) payload
    Absolute ceiling: 40,386 ft (12,310 m)[131]
Blackburn Beverly
Specifications (B-101)
    Crew: 4 (2 pilots, radio operator and navigator)[8]
    Capacity: [8]
        94 troops or
        70 paratroopers
    Length: 99 ft 5 in (30.30 m)
    Wingspan: 162 ft 0 in (49.38 m)
    Height: 38 ft 9 in (11.81 m)
    Wing area: 2,916 sq ft (270.9 m2)
    Aspect ratio: 9:1[8]
    Airfoil: RAF 34 (modified)[8]
    Empty weight: 79,230 lb (35,938 kg)
    Max takeoff weight: 135,000 lb (61,235 kg)
    Fuel capacity: 6,880 imp gal (8,260 US gal; 31,300 L)[8]
    Powerplant: 4 × Bristol Centaurus 173 18-cylinder air-cooled radial engines, 2,850 hp (2,130 kW) each
    Propellers: 4-bladed de Havilland reversible-pitch propellers, 16 ft 6 in (5.03 m) diameter [8]
Performance
    Maximum speed: 238 mph (383 km/h, 207 kn)
    Cruise speed: 173 mph (278 km/h, 150 kn) (recommended cruise)
    Range: 1,300 mi (2,100 km, 1,100 nmi) at 8,000 feet (2,400 m) with 29,000 lb (13,000 kg) payload; 160 mi (140 nmi; 260 km) with 50,000 lb (23,000 kg) payload
    Ferry range: 3,960 mi (6,370 km, 3,440 nmi) at 8,000 lb (3,600 kg) (with 1,000 lb (450 kg) payload)
    Service ceiling: 16,000 ft (4,900 m)
    Rate of climb: 760 ft/min (3.9 m/s)
    Take-off distance to 50 ft (15 m): 1,340 ft (408 m)
    Landing distance from 50 ft (15 m): 910 ft (277 m)
Quote from: Scotaidh on June 09, 2021, 01:52:52 AM
They could, but then the more than doubled speed might yank the landing gear off, and then they'd need to make them retract and then you've got a whole 'new' aeroplane.......
I would have thought that a re-engined Argosy would be more appropriate.  I suppose that the C-27 could be lengthened if needed or the Kawasaki C1 which has been offered to Australia. Then there's the An-72/74 which could find its way to replace the BAe 146 or the C-390 another twin turbofaned,  Hercules size aircraft.
Nick
Isn't it time to rebuild the Short Belfast? Or a smaller version called the Shorts Derry?
Quote from: Nick on June 09, 2021, 04:56:34 AM
:thumbsup: :thumbsup: :thumbsup: :thumbsup:
