Main Menu
avatar_Vulcan7
Avro Woodford Jet • FIN •
Started by Vulcan7, September 18, 2023, 06:37:40 AM
I LOVE the way you do those magazine entries and box-top things!  :wub:
How about a teach-in on how you do it please?
Vulcan7
Sure I'll try and do a step by step guide in the modelling tips etc. Section. You will need some kind of Photoshop or equivalent  :thumbsup:
Oh that's a lovely job, and the kit box and magazine article are great!  :thumbsup:  :thumbsup:  :thumbsup:
Quote from: PR19_Kit on September 28, 2023, 08:33:43 AMCanard aircraft have a very wide CG range apparently, I'm not sure why, but they do, so the bomb bay in the middle of the fuselage should work fine.
It's not so much canards as tandem wings that have the wide CofG range. Basically, you can adjust the centre of lift by always applying an upwards trim force at one end or the other, and since both surfaces are large, you can do it with relatively small trim surface deflections which don't induce much drag.
Very good build and presentation using the boxtop and magazine images.. very inventive.
 Is the masking still on the rear turret transparencies ?
Vulcan7
Quote from: buzzbomb on October 03, 2023, 02:26:42 PMVery good build and presentation using the boxtop and magazine images.. very inventive.
No all gun turrets are remotely controlled on this version so they are not transparent
Quote from: Vostoc7 on October 03, 2023, 03:17:15 PM
Quote from: Vostoc7 on September 28, 2023, 01:52:50 AMTo be honest I'm surprised no-one has done this design by now as the book came out in 2004.
Fantastic Plastic did a resin version of the cover aircraft (Vickers?) in 1/144th scale. I've seen one or two at shows.
Vulcan7
Quote from: Weaver on October 04, 2023, 03:44:54 AM
cool thanks I'll have a search for pics  :thumbsup:
Quote from: Weaver on October 04, 2023, 03:44:54 AMFantastic Plastic did a resin version of the cover aircraft (Vickers?) in 1/144th scale. I've seen one or two at shows.
The late great Mike McEvoy built more than a couple of them, it's a really good kit, but not cheap of course.
smeds
