avatar_Allan
Let's talk about yellow; so hard to paint
Started by Allan, September 04, 2005, 05:54:16 PM
Allan
Hi blokes,
Yellow-what brand do you prefer and how do you paint it on?
I've had tonnes of trouble recently trying to put some yellow paint on the nose and wingtips of a German plane I'm making. Put on a thin coat and you're faced with putting on about 50 before it covers properly. Put it on thick to begin with and the surface detail goes poof!
Nothing seems to work properly with a brush and I've tried Humbrol gloss and Lifecolor German yellow. Even with a light blue undercoat.
A few years ago I used Testors flat white when I was having brushed white paint trouble. Maybe Testors flat yellow is the go.
Tips, please. Is Floquil yellow really the holy grail of yellow that I've been hearing about?
Allan in Canberra
I've used Tremclad rust paint before, gloss cost over a coat of flat white, with good results.
Spray is the only way, if you ask me !
Allan
Thanks, Todd.
That Testors flat white I referred to was in a rattle can and went on beautifuly, which leads me to think that the yellow may well perform in the same manner.
Has anyone tried Xtracolor enamel yellow with a brush?
Allan in Canberra
Ollie
Here's what I do.
I prime the area to be painted in white red or yellow with Tamiya IJN Grey or RAF Sky.  Then I apply the white/yellow/red.  It works wonder!
Allan
Thanks Ol.
Actually, I primed with Humbrol flat light blue and the yellow still didn't cover properly.
What do you think about Xtracolor RLM yellow or Tamiya flat yellow instead?
Allan in Canberra
[QUOTE
Yes I have Al. Need a flat white/light grey undercoat and then a couple of coats, same with Tamiya acrylic but your'e right yellow is a absolute buuger.
Allan
Chris,
Isn't it just? That and white and sometimes red. I wonder how Vallejo would go?
Allan in Canberra
For white I use Halfords spray cans (obviously not available in Oz).  Don't know what their yellows are like.
Dork the kit slayer
#8
http://img.photobucket.com/albums/v11/anju...cs/Mentor1g.jpg
http://img.photobucket.com/albums/v11/anju...Finnish109b.jpg
I use a Tamiya  (mixed) yellow (airbrush)  misted over a white base coat .
I did these a couple of years ago,and dont think the yellow hides the detail  especially on the mentor (its a really small kit) :wacko:
with hind sight  :dum: I could have done with a panel line wash on the 109 , just to pick out the detail .....preshading works for me these days.
Ollie
I use all sorts of yellow, doesn't matter if it's Tamiya or Gunze, and they all go down as esily using my little primer.
If it's only a small yellow area, I tend to brush paint a couple of thin coats onto the area that needs to be painted, and I mainly use humbrol enamels
TsrJoe
iv found the larger size (cheapo) Humbrol Gloss spray cans give good coverage, especially on top of a coat of matt white, heir yellow and red both being good!
car sprays again generally give ok coverage, most match 'standard' military shades too (eg 'trainer yellow')
hoping this helps, cheers, joe
Mike Wren
#12
I use Halfords (Ford?) Broom Yellow aerosol over white primer, gives a good impression of the RAF & Canadian yellows for SAR helos
noxioux
The white base coat is the only way I've got yellow to work at all.  I have similar trouble with some of the bright red enamels, as well.
One thing from my meager experience with paint, there are some kinds of bases that just don't cover (in house paints, these are usually called "accent" bases).  A lot of bright custom colors use accent bases, and they are a real bear to get any coverage with, even with 4 or 5 coats.
I'm thinking that most of these paint manufacturers are using similar bases in order to get that yellow as bright as possible.  But if you use a flat white for an undercoat, it seems to work pretty well.
Allan
Thanks Noxioux and others.
I've some Polyscale flat Reefer white railroad paint (acrylic), so I might put down a thinned coat of thet and then some Lifecolor.
Allan in Canberra
