Morskoj Spitka....
Started by wolfik, February 08, 2006, 11:18:56 AM
There aren't enough superlatives in the English language to compliment you properly on this.
:o
K5054NZ
Comment seconded, Nev.
Jeez, you're a modelling GOD! Peter, thank you! PAINT! NOW! Like a Rufe, but infinitely better
Patrick H
Grear stuff Wolfik, I can hardly wait to see the finished product.
Patrick
My webpage
Brilliant Peter, stunningly brilliant!
wolfik
hi all! :cheers:
thanks for the flattering comments!!!!! :wub:
will see what can I do as next :dum:
regards to all moony "kitters" here! :cheers:
You are the Jedi Master of Modeling, Peter!
:ph34r:
Bryan H.
Beautiful!   :wub:  B)
:cheers: Bryan
My son & daughter.
School - finishing my degree
Models (upcoming):
RCN A-4F+ ArcticHawk
The Twin-Float Spitfire that I presented to complete Wolfik's Single-Float Spitfire was a Japanese model of 2003 named Floatfire, see http://www002.upp.so-net.ne.jp/Matsu-chiyo...pit-5-float.htm . Wolfik's asked me if it was 1/48 too, but I do not read (fluently enough) Japanese to answer. Which one of us do?
Anyway, between Twin-Float Spitfire and Single-Float Spitfire, my choice is: Twin-"Single-Float-Spitfire", also called "Twin-Float Twin-Spitfire", not from Supermarine but from the team Wolfik-Tophe. See the picture on the twin-tail forum at
http://www.whatifmodelers.com/forum//index...80&#entry118324
With Soviet stars someday, it may be called WorkfikToff Dvukh-Morskoj-Spitka...
elmayerle
A small spot of technical nitpicking from a structural viewpoint.  It seems to me that both Spitfire and Bf109 floatplanes would be able to save a bit of structural beef-up by tying the struts supporting the main float(s) to the existing points the main landing gear legs tie to instead af adding structure to mount the floats to the wings or a single float directly to the fuselage centerline.  For a single float, I'd use a narrow V-strut with a small stabilizing strut at the back while two-floats would get canted struts similar to the ones for the ski-equipped Bf109E.
--Jane Wagner and Lily Tomlin
QuoteThe Twin-Float Spitfire that I presented to complete Wolfik's Single-Float Spitfire was a Japanese model of 2003 named Floatfire, see http://www002.upp.so-net.ne.jp/Matsu-chiyo...pit-5-float.htm . Wolfik's asked me if it was 1/48 too, but I do not read (fluently enough) Japanese to answer. Which one of us do?
I had a friend of mine in Japan check out your Japanese text link there, Tophe:
It is actually the Russian kit manufacturer "EASTERN EXPRESS" and kit #72206.
I'm told they only make 1/72 aircraft kits.
Here's the kit
http://www.aviapress.com/viewonekit.htm?EST-72206
and here's a site listing all of Eastern Express' products (I only have one little Tupolev kit from them and have never built it):
http://rosemonthobby.swiftsite.com/eem.htm
mgp
You've been sneaking peeks at my What-If To-Do list haven't you?? Thief, thief!!  :P
I was pondering doing a single float RAAF Mk8 Spitfire in Grey Nurse markings  using the floats from a Rufe.  The single main float just looks so much better than the twin floats - much sleeker and Spitfire looking.
Can't wait to see what the finished item looks like.
Hominem Iniocosum Non Diffidite
The page http://www.fortunecity.com/tattooine/farme...0/spitfire.html seems to confirm the Twin-Float Spitfire was an actually built prototype, which is sad, while Wolfik's Single-Float Spitfire is a pure what-if model, great!
:P
wolfik
hi
yes it was planned to use these (IX ,one built) in the pacific in 1943 but the us art to make war was simply better  :tank:
the prototype was back configured to the "wheeled" aircraft
have some pictures from a polish monografie book
regards!
