P
F-105 bash
Started by purple_haze4, May 28, 2006, 10:36:31 PM
purple_haze4
Hey guys im new here but i came with an idea. I have a 1/48 F-105 body but nothing else no stabilizers or wings just body and tail. So what do you guys think would look good bashed with a F-105 body im open to anything
Wings off a better plane, say a F15? Su 27?
purple_haze4
F-15 probably but should i add the F-105 intakes or F-15 intakes
elmayerle
If you're staying with a single engine, use the F-105 inlets blended into the root of the F-15 wings.  A pair of 1/72 F-15 inlets would work well, though, if you had then to spare.
--Jane Wagner and Lily Tomlin
purple_haze4
If anyone knows how to make digital renders of 3d aircraft feel free to make a model of wat you think would look good
Radish
Forget the wings....go for a "Hot Rod" racer :wub:
Or, add wings from anything and make it a space-interceptor??
Add little stubby wings, finlets and make it a vertically-launched rocket interceptor :lol:
Land speed record setting car ?
High speed mini-sub ?
ICBM ?
Dork the kit slayer
pulled by reindeer...."Santas (led) sled".............I know .......Ill get me coat :D  :D
Archibald
delta wing, with air intakes in the wing roots a la Hunter...
elmayerle
Quotedelta wing, with air intakes in the wing roots a la Hunter...
But keep the F-105's Fieri inlets.  Those on a delta wing would look wicked. ;)
Archibald
Fantastic idea!!!
I'm always asked  myself why the F-105's air intakes were oriented forward??
I never saw that on another plane...nevertheless, this feature combined to a delta wing would be great!!
I'm guessing that if you only have the fuselage then you don't have the wing-root intakes. I like the idea of delta wings, but for the intake maybe you could go for the nose with a central shock cone/radar setup, like the Mig-21.
Sentinel Chicken
QuoteFantastic idea!!!
Good question. All I know is that it had something to do with shaping the shockwaves to prevent engine stalls.
No NO NO NO[span style=\'font-size:21pt;line-height:100%\'] NO!!![/span]
It was to make it look wicked cool!  :P
elmayerle
#14
Fieri inlets on the F-105B and subsequent models.  A different approach to letting the shockwave do most of the work, efficiently, and keeping the moving parts in the inlet to a minimum.  The F-103 was designed with one, as was the original Vickers 571, and the Arrow Mk.3.  It's a bit more tricky, structurally, than other kinds of inlets, but it has its uses.  Not to mention that it looks, as Rat said, wicked cool!.  I'm doodling a set on an upgraded Draken.
