avatar_elmayerle
Hawker Hunter
Started by elmayerle, April 13, 2005, 09:59:08 AM
Cliffy B
#195
Oh good!  I'm looking to make a fully operational line bird out it rather than just a trainer so awesome!  It doesn't come with the option for all 4 20mms by chance does it?  I might be able to use the Revell kit to get those....hmmm....
-Tom Clancy
-Anonymous
-Anonymous
I read in SAMI that a Hunter T.7 is due for realease by someone, can't remember who, think it was MPM or AModel maybe.  I'll have a look later & see if I can find it.
Howard of Effingham
Quote from: Mossie on July 09, 2010, 02:43:16 AM
if you do look, mossie i don't think its too precise as to exactly who is doing it be it resin or limited run injection molded.
Keeper of George the Cat.
The snippet says that "someone has commissioned a large Czech manufacturer to produce". So whats the betting it will be Xtrakit ? It's the way they do things, although they've been using Sword who I wouldn't call "large" but thats only a personal take.
I'm considering building a Hunter F.6, preferably in 1:72 (XG210). The only F.6 kit available at Hannants is an expensive resin one. I've seen some favorable reviews of the Revell kit, but that's OOP. How do the others (Airfix?) compare?
It seems the FGA.9 kit should be fairly close, can I use that instead?
Yes, you can use the Revell Hunter FGA 9  You'll have to leave off the overwing blisters, the flaps don't have the circular cut out so no need to alter the kit parts.  The only surgery it'll need is to the tail pipe section to remove the parachute housing.  However, I may have that section spare from an F6 that's going to be a 2 seat P.1083.
I take it the expensive resin one is the PJ kit?  It's nice but too short.  I got one on ebay last year for just under a tenner - the price of the Revell kit.
Quote from: Cliffy B on July 08, 2010, 04:51:47 PM
The trainers could only ever carry 2 at most.  TBH, there were many who considered the Hunter to be overgunned with the 4 30mms.
James
I've read that about the 4x 30mm. However, two guns just wouldn't look as good - with four ADENs the Hunter sure looks like it means business.  :wacko:
Lee's beat me to it.    Another difference between the F.6 & FGA.9 is that the latter can use larger 230 gallon drop tanks on the inner pylon.  Apart from that, they're pretty much the same.  The Revell FGA.9 kit has both sizes of drop tank, not sure about the Airfix kit.
From what I can gather, the Airfix kit isn't bad, although the Revell kit is the one to go for being much more modern & generally more accurate.  You should be able to get a Revell kit, they'e oob, but only recentley & many places still have stock.  Proabably easier to get than the Airfix kit.  If Lee can't spare the F.6 tailpipe, I should be able to as I have the same conversion.
Try giving Tim (thedarkmaster) a shout as he works at Modelzone & they recentely had both Revell F.6's & FGA.9's for five pounds, still should work out reasonable with postage to Holland.  I also think Ian Hunter Gatherer was lettting some go in a stash sale recentley, not sure if he got rid of them.
I mentioned before about a Hunter trainer, it's been the proverbial bus, none for ages then several at once.
Olimp is the resin manufacturer I alluded to, they have three different kits on offer.  A T.7C/T.8C/T.53, a T.66/T.66A/T.66B/T.68 & a T.8M (the one with the Shar FRS.1 nosecone).  All going for £35.99.
Olimp Hunter trainers on Hannants
Xtrakit is also offering an injection T.7, listed at £17.99.
Xtrakit Hunter T.7 on Hannants
The Olimp is a copy of the Revell kit.  I'll get one of the Xtrakit ones...
Quote from: The Wooksta! on December 01, 2010, 04:15:27 AM
At least a couple of Pakistani F.86 pilots would concur with that statement. I remember an article in Air Enthusiast eons ago about one of the Indo/Pakistan wars which described a couple of air-air engagements between Sabres & Hunters. A couple of Sabres simply disappeared in mid air
Quote from: NARSES2 on December 01, 2010, 07:48:53 AM
But wasn't the concept of having four large cannon mainly because the main targets were supposed to be the bombers.  I remember reading the book 'I Flew for the Fuhrer' by Edward Knox where he describes attacking B-17's and B-24's in the Me-262, he said along with the rapid closing distance and the vibrations of the aircraft, most of his shells went either over or under the target. Mind, they were slower firing guns than the Adens.
£36 for a 1/72 Hunter?
For goodness sake, has the world gone mad? No way would I EVER pay that much for a kit that size, it's ridiculous.  :banghead:
Quote from: kitnut617 on December 01, 2010, 09:17:55 AM
They also had a low muzzle velocity, giving them severe drop at combat ranges, which didn't help either. The original ADEN ammo (30x96mm?) was almost as bad, but then they compromised a bit and went to 30x113mm. It's still the lowest-powered commonly available 30mm cannon ammo though.
