avatar_nev
Mustang: F-51, A-36, F-82, Cavalier, and Piper PA-48 Enforcer
Started by nev, January 27, 2003, 11:32:53 PM
Here's a question I can't find answer to, simply because it doesn't seem to be mentioned anywhere.
Did any P-51 variant ever have a pressurised cockpit, and if not, why not? As it could get to almost 42000 ft I'd have thought it was a must. Or did ALL of them have pressurised cockpits and no-one thought to mention it anywhere?
raafif
AFAIK some pilots were issued with a "G-suit", actually JUST a pair of über-tight leggings -- this with the oxygen-mask was deemed good enough for 1944/45.
= pressurised cockpit + long wings + extra engine blower =  :unsure:
sideshowbob9
QuoteUnlike photo-reconnaissance versions of the P-38, the F-6 retained its armament, being used primarily in low-altitude operations where it might have to defend itself.
Source: http://www.history.com/topics/p-51
Admittedly, this doesn't rule out the existence of a pressurised cockpit variant at all and doesn't mean you can't have a high-altitude F-6. They should afterall have a comparable service ceiling to their P-51 siblings.
I'm assuming you are thinking of a photo-recce machine, as no period bomber can get that high to escort and you wouldn't need an interceptor up there.... unless the Germans persisted with the Ju-86P/R.......
You two guys know me too well...........  :lol: ;D
Yes, I'm thinking of an F-6H, naturally with longer wings, which would give it almost parity with a Spitfire PR19, the majority of which did have pressure cabins although the earlier productions ones didn't. With 'only' a Merlin to haul the Mustang up to the 45000 ft mark it may need a bigger supercharger to give it enough oomph to drive a cabin blower, but I wondered if I'd need to make visual changes to the canopy, the only visible differences between the early PR19s and the later ones is the absence of a side door and different canopy slides on the later versions, plus the small air intake on the lower left of the cowling.
I'd suggest the same changes for the Mustang, then, & lose the guns.
....... Wonder what a Griffon engined Mustang would look like? ;)
Quote from: Old Wombat on August 12, 2011, 01:47:55 AM
Like this ---
It used an old Shackleton engine and prop (shortened of course) and a Learjet wing. 'Used' because it crashed later.
And there's this one too ---
BTW, High Planes Models does a kit of both of these, got a copy of each in the stash.
Personally, I'd start with a P-51B/C as the high-back Mustang version would probably, in RW terms, be easier to pressurize.
Also I just think they look better than the D model.  ;D
... or of one did go the D route, perhaps a metal reinforced canopy similar to the third DH 108:
... or even portholes like the Vulcan.  ;D
raafif
definitely go with a B/C model -- stronger canopy area plus an extra 3mph of speed over the bubble-top version (better streamlining).  You'd lose the extra speed due to the increased weight of this version, but it's handy to have it to lose.  Less guns too for a PR but add humongous camera windows !
Just how much longer will the wings be ???
7' longer, 3'6" per side as that's the width of the styrene strip I had handy.  ;D
And I'm starting with an H as I have one handy, but I like the idea of the metal canopy with portholes.
Moving on to props, almost all P-51Bs seem to have had cuffed props, as did most P-51Ds, but some Ds had uncuffed props. P-51Hs all had uncuffed props AFAIK. What's the performance difference between the two types and why did they change?
johnsjunk
Here is my F-51-R Interceptor Griffon powered Mustang using the High Planes "Precious Metal" kit.
F-51-R MUSTANG INTERCEPTOR 1/48th scale by john's junk, on Flickr
A nasty-looking airplane, if you are an enemy!
PACOPEPE
Here my mixed powered-forward swept wings "P-51 FS-J".
Fran
Nothing new under the sun! Had the idea to use an F-82 with the complete wing, but only one fuselage and new stabilizers to create a high-altitude interceptor version (think Me 109 --> BV 155). Turned out Wyrmshadow already did this a couple of pages back. :lol:
Here's the drawing anyway:
When looking at the profile of the F-82's long fuselage again, another thought hit me.
Just so.
