avatar_Daryl J.
Monogram What-ifs
Started by Daryl J., August 23, 2006, 07:27:15 PM
Daryl J.
As many here likely know, ARC is going to have a Monogram ''Classic'' kit group build.   Here are a couple of ideas popping through Ye Olde Head at the moment and I wonder if they are reasonably viable:
(Both 1/48 Monogram kits)
P-39 with P-38 intercooler ducting, armor plating around pilot and radiators, painted in Vietnam Green/Green/Tan/Grey.   Nape carried beneath.
B-29 with approximate 3-inch extension split immediately fore and aft  the main wing enlarging the bomb bays, utilizing tip tanks, prop revisions, turrets removed, and  in Vietnam Green/Green/Tan/Black.   With the left-over Superfort, making a B-29SP ground attack variant.
Reasonable?   What have I missed?
Essentially, I wanted a Tigercat, Mitchell, Aircobra, and Superfortress all in SEA-whiffery.   :party:
Thanks in advance,
Daryl J.
Those are some awesome ideas, Daryl! I'm looking forward to seeing them come to fruition in the Pics of Your Current Projects thread!
A latter day B-29 might utilise turboprops...  :)
ya, and you could get that resin conversion set for the Chinese AWACs.....now that would really make a tough looking -29 !
Radish
Great ideas, and they'll help to get my "Vietnam" P-61 back on track :lol:
Daryl J.
The MO of the short-fuselage B-29 would be that of trail strafer and ground attack.   Would that mean a designation of A-29SP be appropriate?  AKA the Asp?
Since turrets would be essentially gone save for some rear protection, I'd thought of adding 3 SUU-22's ( is that the correct designation?) from the Monogram F-4C/D kit underbelly much like the Mitchell incorporated side guns under the canopy.  A smaller bomb bay with some daisy cutters, phosphorus, or napalm to be included.   Regarding engines, the 3350's were mighty fine engines and would be on-line since the Skyraider used them as well.   A prop revision would likely happen, however.     No tip tanks at all, but perhaps a reduced span wing outboard the engines?
The P-39 would be used in much the same capacity.......................albeit on a much reduced scale.
Now off to fill in the over-shallow gun troughs on Monogram's Bf-109G-10 and add some recce bits....also a US Vietnam aircraft btw!  You know that German engineering is built to last and the sound that thing made.............. :cheers:
:party:  :party:
Daryl J.
Quoteand they'll help to get my "Vietnam" P-61 back on track
You too???
