avatar_lancer
EE Canberra and Martin B-57
Started by lancer, March 04, 2004, 01:51:18 PM
MadJack76
@ Old Paul,
You could use the wings from a Tamiya 1/100 scale B-52 for that, they look pretty similar.  You'd need to cut off the outboard 1/3 of the span, slice away the pylons, then splice the wings to make room for the B-57's engine pods.  Glue together, smooth over with putty and attach to the B-57 fuselage and you're set.
Here's a page from the Flight Archive.  It shows two early designs for the Canberra, but most interstingly there's the proposed airliner version, with larger 10ft fuselage and a low mounted wing. http://www.flightglobal.com/FlightPDFArchive/1958/1958%20-%200319.pdf
loupgarou
Lovely  :wub:
the airliner is really a shorty. It already gives me ideas. ;D
OGL built the Canberra airliner IIRC, it takes some thinking to realise that it IS a Canberra!
Quote from: PR19_Kit on January 17, 2013, 05:13:45 AM
I would say as about as much as this is a Vulcan, Kit  ----  :lol:
I like the rear facing seating!!
Most airliners were planned that way and all RAF operated transport had rear facing seats.  It was only consumer pressure that makes the airlines have forward facing seats.
The few remaining VC10 C1s still do have rearward facing seats.
BEA's Trident 1 & 2s had rear facing seats in the front 3 rows of Tourist Class which meant you faced the other passengers if you were in the rearmost row of those seats. Mrs PR_19 and I once got three lots of drinks and three meals on a trip back from Berlin once by using that arrangement to our advantage (it's a long story......  ;D) It was great on landing but with the steep take-off angle of Tridents on the Berlin route it was a trifle un-nerving as you hung in your seat belts as the aircraft climbed out!
And yes Robert, it DOESN'T look much like a Vulcan.  ;D
So that's what an Avro Atlantic should look like. I wonder what happened to the build that was on here some time ago?
Quote from: Gondor on January 17, 2013, 02:33:25 PM
Um! this one ---
USAF still uses rear-facting seats in all its troop carrying aircraft.  It is safer, particularly in case of a crash on take-off or landing because of the deceleration forces involved.   As mentioned, civilian passengers like to see where they are going, not where they have been, so forward-facing seats are now the norm for them.   BTW, when travelling by train, it is always safest to choose the rear-facing seats, for the same reasons.
Quote from: rickshaw on January 17, 2013, 04:12:58 PM
You can say THAT again! Having been aboard a test train that went clean off the end of our test track at around 50 mph I can confirm that rear facing seats on trains work a treat in an accident.  ;D
Briliant build, I wonder if I could use the Vulcan wings on a 1/144 Boeing 747 :banghead:
loupgarou
Quote from: McColm on January 18, 2013, 11:23:07 AM
Brilliant indeed, Wooksta.  :thumbsup:
McColm: or you could use a Boeing 707 or similar on the same scale as the Vulcan for a slender look.
