avatar_lancer
EE Canberra and Martin B-57
Started by lancer, March 04, 2004, 01:51:18 PM
It is a pity.  However, I suspect, knowing how tough the Canberra is, they'll have it back up on it's undercart in no time at all.    :thumbsup:
Doesn't look too bad. Trick will be getting parts for an aircraft that old.
Quote from: kerick on March 08, 2019, 05:46:32 PM
Parts from a boneyard?
IIRC the RB-57F still used the original Canberra nose wheel design, so there'll surely be some bits available in yards around the UK if they ask nicely.
This video from Scott Manley includes video shot from one of the NASA WB-57Fs of SpaceX's Dragon crew capsule re-entering after it's successful (unmanned) test flight to the Space Station:
https://youtu.be/Q8LUbag1bS0
WB-57 foootage from about 4:10.
Wow, that thing's certainly motoring across the sky!  :o
And very impressive camera tracking too, it was really locked on.  :thumbsup:
USAF B-57 Combat Transport.  Found on Secret Projects and posted in a different thread, thought they belong here:
https://www.secretprojects.co.uk/threads/martin-vb-57-vip-transport.13348/
Edit, duplicated an image, fixed it.
I've looked a bit closer at using a Dominie nose to create this and it's possible, with a bit of shunting and reshaping.
They'd have needed the tip tanks to get any reasonable range I'd have thought. The pax seats are right where the fuselage fuel tanks are installed in many Canberra variants.
Makes sense, I did wonder why they were so much larger than the standard tanks.
Quote from: Mossie on June 14, 2021, 02:20:03 AM
Simon, the Dominie fuselage is a little bit bigger than 6'-0" diameter, the Canberra fuselage is 7'-0"
Quote from: kitnut617 on June 14, 2021, 06:03:05 AM
A quick measurement on a Matchbox HS 125-600, an Airfix B(I).6 and a Matchbox PR.9 gives that the Canberras are about 1mm wider than the 125 in 1/72. I say this is very doable, if with some adapting and PSR.
Hmm.. I need to dig out my Airfix Dominie..
The engines could also be replaced with JT8D engines (instead of thirsty J79s or their civil counterparts, the CJ805)? There are resin nacelles for the DC-9 around in 1:72...  ;)
Quote from: Pellson on June 14, 2021, 06:27:42 AM
I've offered the Airfix Dominie and Italeri B-57 up to each other and they appear very  close.  I'm going to start it tonight for the 1WGB, although it'll be pushing it...
Quote from: Dizzyfugu on June 14, 2021, 07:45:05 AM
The B-57 had J65s (license built Sapphires), so not too thirsty.  A J79 wiff wouldn't be a bad idea for something a bit more high performance, like Brian's B-57E:
https://www.britmodeller.com/forums/index.php?/topic/235023713-martin-b-57e-super-canberra/
