Douglas SeaRider
Started by wolfik, October 29, 2006, 08:03:09 AM
wolfik
hi
the next one is the idea to make the skyrider something longer and with an upper remote controled turret...
the turret was made from a resin stick casted in  paper rolled to adequate diameter, then sanded and some engraved lines was added.
the fuselage was lenghtened and with the grey 3mm forex plates the place was closed and sanded in shape...
the cowling was changed to the lenght of PW 4360-59W engine.
instead the under wing configuration it will be installed a mid wing made from
schratch from forex too.
maybe a contra rotating prop will be installed...
wolfik
o..its the monogramm kit
Could you please teach your technique for lengthening the fuselage?
GeorgeC
QuoteCould you please teach your technique for lengthening the fuselage?
Oh yes please - how the hell do you do that so neatly?
SimonR
Yes! Yes! Bitte! I'm sure the resin casting paper tube method is more complicated than your nonchalent description implies.
This model is 100% awesome, BTW.
Simon
Hunter S. Thompson
Woah is that clean, Herr Wolfik! I can't wait to see it finished....are you thinking Navy colors or maybe that cool SEA camo?
Can somebody please point me to a finished Wolfik model ? I recall 1 ( one ). But damned if I can find it !
That thing is awesome !
anthonyp
Looks nice so far.  Can't wait to see it finished!
I do beleive the technique Wolfik is using is the Jade Beetle Fuselage Lengthening method, as taught by the Shaolin monks of Barbados.  They can make you 3 inches taller with one touch!   :ph34r:
:cheers:  :cheers:
I exist to pi$$ others off!!!
Go get 'em wolfik, there's a lot of whiffing potential in that bird!  ;)  :wub:
QuoteI do beleive the technique Wolfik is using is the Jade Beetle Fuselage Lengthening method, as taught by the Shaolin monks of Barbados.  They can make you 3 inches taller with one touch!
Hmmm... Can they do anything about my... never mind...
wolfik
hahahahaha  ;)
its possible Rat but...the polystyrol implant dont works...trust me...eee...never mind... :unsure:
wolfik
by the way I will make an article for anyone who is interested on tips&tricks in some days ok?
many thanks for comments guys!! :cheers:
Archibald
nice, good idea! that's give me an idea for a Skyraider with a Defiant turret on it's back... :wacko:
As usual, I like your execution :wub:  :wub:  :wub:
Do you like Skyraider's tail fin. I have not found a way to style it properly yet.
Chap
Awesome work as usual Peter! I would also be interested in your lengthening technique; I have a Lancaster project that is in need of a good stretching.
~Steve
