avatar_Archibald
B-40 Mixfortress is back...
Started by Archibald, November 07, 2006, 06:57:25 AM
Archibald
On demand of B-777LR the other day :)
This was my old B-29 highly modified with bubble canopy, T-tail, jet pods ala Caravelle. I planned to replaced the R-3350 by T-56 (from a C-130) but this seemed wrong. In fact the fuselage looked quite "modern" whereas the wings and radial engines looked old fashioned...
Only solution was getting ride of the engines, but this implied cutting the wings in 6 parts... after much hesitations I finally decided to go forward.
In the end I knew that cutting the exterior engines would complicate things, they are part of the wing.
The two jets on the rear are quite unsufficient I agree... the good news is they come from Mach2 Falcon-20 (which has two pair of different engines) and I plan to buy another (to change into a Carreidas 160). This mean two more engines for this thing... other problem is to know WHERE to place it on the plane. As I just love the Martin XB-51, I think it could be cool having two more jets hanged below the cockpit :)
In brief : here's the result.
weird but beutiful, and... german! Looks like luft `46
If you want to make the fuselage and wings look better, try glue some tin foil on, with PVC glue  B)
Yeah, looks very Blohm & Voss-ish, a bit like their W winged bombers.  Good job Archie!
Archibald
Glad you enjoy it, guys! wooksta, I've not yet  a precise idea for the engine location, so every suggestion is welcome :)
Jamatari
#4
What about the engine in the fuselage ? some big side mounted intakes near the middle gunner position
B777LR Wrote
"If you want to make the fuselage and wings look better, try glue some tin foil on, with PVC glue"
I've covered my b-29 in foil well 40% it looks good but ive go bored now and gonna try some of that alclad II stuff to finish it
James
http://www.exfix.co.uk --Kits and whatifs
Woah arhcie this one is sooo cool it rocks! I really like your modifications, especially the canopy and the T-tail (I'm sure Baz will agree)! What kind of paint scheme and markings do you have planned for it?
Archibald
Russians markings, for sure! I plan to add big number below the fuselage (you know, things like 006, 47 or 105. Never understood what this numbers meant). I've got 74 (or 47) left by my Heller Viggen.
Do you think this grey color (humbrol 56) fit well to a Soviet aircraft ??  :unsure:
I'm still reflexioning over the engine location...
ala VC-10 would be something (adding two engines to the two already in place!).
On pylons (2 or 4) below the wings...on the wingtips...above the wing...
I really want to keep on with the rear turret, so I don't think that there will be internal engines...
I'm really thinking about a M50-like engine location (engine on FSW wingtips  :wacko: )
The main undercarriages were fixed in the  turrets holes (the rear undercarriage even use the pivot of the turret  B)
Wheels come from the Jag / P.146, the canopy from a P-47.
I'll check the former thread...
Archibald
Here's the old thread
http://www.whatifmodelers.com/forum//index...2&hl=xb-40&st=0
I've tried wingtips engines+nacelles below the cockpit.
Here's the result...
Just posting that, I've got a f....antastic idea!
Heller has made a C-135FR... I could ask them the four engines pods!!! Now that would be something!!!!
How could you possibly ask a non-excisting company for parts that they produced when they excisted?
Archibald
^_^  Knowing you Mr Boeing-san  I think it's a joke, related to another thread...
Archibald
Ok, two jets on the wingtips, and two on underwing pylons
frank2056
I like the design; the bubble canopy looks great! The center of gravity could be further back towards the tail; maybe it's the FSW but the plane looks tail heavy.
I like the engines next to the cockpit; they remind me of the XB-51 and Ju-287 - I think an extra set under the wings would look better than wingtip engines. A failure in one of the wingtip engines could force the airplane into an unrecoverable spin.
Frank
Archibald
Frank I think I already fiound your website some weeks ago -maybe a link gave by a member here, I think it was on your German jets collection- .Good work, really!!!
In the end, maybe two jets below the cockpit and the other two in wing pylons.
And I'm also a great fan of the XB-51 (cool but unlucky aircraft. What was the problem with this one ?? :huh: ) an extraordinary looking aircraft!!!
Archibald
That's right, the engines now seems too little...perfect as boosters for piston-engines, too little now...
works stop now for some days... see you soon guys!!!
