avatar_ysi_maniac
Fulcrum with CFT
Started by ysi_maniac, December 05, 2006, 05:46:11 AM
Main problem of MiG-29, a COOL fighter, is fuel consumption. Inspired by a real paper project (Boeing Enhanced Phantom), I tried a Conformal Fuel Tank for the Fulcrum.
Would this cft had a major impact in aerodynamic performance?
I see one problem: in a standard Fulcrum, boundary layer between fuselage and air intake is deflected half inwards and half outwards; with this cft it cannot be deflected inwards. Should it be deflected 100% outwards? or should the inwards half be canalized in a certain way between fuselage and cft?
Aerodynamics expertise, hot shot engineers, etc... needed. Sugestions will be very wellcome.
Thanks in advance,
Carlos.
Very cool, i also have had this idea in my head for some time! :wub:  I dont really see any problem with it. Besides, its what-if!
wolfik
cool looking!!!!
how much fuel could be in such extra "tank"?
I calculated about 2250 litres
What scale is it? What country will it fly for? (make it russia please!!!!!)
It is ESCI's 1/72. A very inaccurate model, that is why I had to add a 10 mm section to the nose.
This will be Sarracen but I am working too in a real model Fulcrum that will have Soviet stars.
Archibald
Nice! Add two others CFTs a la Rafale (on the back)!
I'd deflect the boundary layer outwards. The position of the nose wheel is a bit unfortunate for that, though. You may need to extend the fairing over the nose wheel cover.
Shasper
In my semi-professional opinion, it would be better to put the CFTs on the dorsal spine or in a similar fashion like on the F-15E & F-16E. If you put in on the centerline you'll lose some lift-generating surface ( yes the area between the engines {refered as the 'Pancake"} does generate a good bit of lift), and you'll limit the weapons carriage by removing 1-2 stations.
Having said that, it IS your model, and who am I to tell you how to build it? :P
SHas B)
- Bud S.
gooberliberation
#12
Mig-29.9-13 with dorsal CFT
Though I do recall reading somewhere that there could also be one between the engines. Mabye do both?
Hey goober, thats a Mig-29S!
Radish
Interesting.
It's a shame no one does a later MiG-29 in 1/48th, other than the MiG-29A from academy.
Or do they?
If I did a CFT like the one suggested between the intakes I'd have to display it flying to show people what I'd done.
Any other suggestions?
I wonder how vav-forming a big dorsal jobbie would work?
