avatar_ysi_maniac
Fulcrum with CFT
Started by ysi_maniac, December 05, 2006, 05:46:11 AM
Rafael
#15
Ysi, way i see it, it's your model, and this is whif. Go krazy, mount as many things you like in that little thing, and, please, show us how much fun you had doing it!!!.
Anímate Carlitos, Suéltate el pelo y echa a volar tu imaginación dentro de ese MiG!!!
Saludos,
Rafa.
Ah! i forgot to tell you: I love it!!!!
:wub:  :wub:  :wub:
1/72 Scale Maniac
YOU - ME- EVERYONE.
WE MAY THINK DIFFERENTLY
BUT WE CAN LIVE TOGETHER
elmayerle
An under-fuselage CFT is not a good idea for the MiG-29, for one thing, it plays hell with the area-ruling and your supersonic drag jumps tremendously.  Secondly, you're now bloking several needed vents and the access panels to the main avionics bays.  Smaller units, worked in above the wing would likely work better, IMHO.
--Jane Wagner and Lily Tomlin
Hi HotShot Engineer
I do not doubt on your point but. Why area rule was not a concern in the case of Boeing Enhanced Phantom. Just to know and take informed decisions :)  :cheers:
Shasper
Well I'm no Ev, but it seems to me that the underside of the F-4 was alot flatter due to the arrangement of the engines than the later F-14/MiG-29/Su-27 that had the podded engine layout.
Shas B)
- Bud S.
elmayerle
Shasper is pointing out the same thing I would've, the conformal tank/pod added to the F-4 by Boeing actually fitted area rual better than the external tank.
Even if it's not practical in the real world it looks pretty sharp, couldn't the vents be sent out the top or is that out of the question?
rallymodeller
#21
As far as Fulcrums (Fulcra?) in 48th, there's the old Revellogram one which, despite its inaccuracies and being an early version, makes up for a fine model (even has a Soviet pilot instead of the standard Monogram guy!)
When the Fulcrum was first revealed in '86 or so, the big fuel tank that nestles between the intake tunnels was thought to be conformal -- I suppose that it might serve much the same purpose.
--Jeremy
elmayerle
QuoteEven if it's not practical in the real world it looks pretty sharp, couldn't the vents be sent out the top or is that out of the question?
Well, they are on the underside for a reason, to prevent accumulation of water when the aircraft is parked outside.  For much the same reason, to protect the avionics boxes while they're being removed or installed, access to teh avionics bay(s) is from the underside.
Radish
Getting intrigued now....and excited by the idea of a big dorsal thingy on a MiG-29 Academy kit.
Thinking of doing the same to an F-18C?????
Goshdanggitall to heck! Logical reasoning sure is a neusance somtimes!  ;)
Whilst not a MiG-29, I recently came across this pic of a Su-30MKK2 - note the 'filled in' space between the engine nacelles, with an M-400 recce pod underneath:
All concerns about "reality" aside (after all, it is at best a pesky nuisance much of the time), I say "go for it."  You've got a very cool concept there and sometimes it's worth simply creating the shape just to see what the novelty will look like.
The idea of combining your idea with an enlarged dorsal CFT as well intrigues me.
Hey, if you need to beef up the under-carriage, you can always do that, too.
It's all good, baby!   :)
QuoteWhilst not a MiG-29, I recently came across this pic of a Su-30MKK2 - note the 'filled in' space between the engine nacelles, with an M-400 recce pod underneath:
Hi GTX, I will think on this idea.
Waiting for almost 4 years! :o
While retaining the controversial CFT, it will suffer additional abuse/s: :wacko: what about a step between MiG-29 and MFI 1.44? :wacko: (I mean canard delta ...)
I will show some model pics soon. :thumbsup:
What's the matter? I have updated and renamed pic and the old draw, with new name, is still here? :banghead:
