avatar_Dork the kit slayer
sometimes things just DONT work out
Started by Dork the kit slayer, December 11, 2006, 07:40:30 AM
Dork the kit slayer
:dum:
First attempt with the new Iwata fine line with some Italian (free hand) camo. I was quite pleased with the results ( for a first time outing)
Then disaster,started to un mask and Im left with a nightmare touch up job
Everybody say aaawwe :(  :(  :(  :( Im sure we have all done it at some time......I just needed to post this..... misery loves company I guess
Never mind...its plan B time. :dum:
But your camo job is wonderful :o
You know: repaint white or, perhaps, aluminium ;)
Archibald
I stand corrected (seeing such camo). No idea of how obtaining such result by myself   :(
Easy to focus on what did not go right....but, hey, have another look at the controlled lines in green----fantastic!!
Did you prime your model?  I use Krylon's sandable grey primer spraycan.
The few times I forget the primer, I run into this same problem.
I say paint it aluminum (as suggested up there) and call it "weathering."
Mambo Italiano !
Very nice.....I like the idea of making some weathering out of it.
;) Wanna buy some white decal film eh ??.... nudge nudge, wink wink, say no more ! ;)
Yep...dry on some aluminium, and then a light brush of powdered white. Make that little tape pull look intentional!
Shasper
In the future, put some Kleer on there before you mask (wish I'd done that with Charette 1, otherwise the masks wouldnt have pulled up so much paint  :angry: )
Shas B)
- Bud S.
Dork the kit slayer
#8
QuoteIn the future, put some Kleer on there before you mask
Shas B)
I Kleerly used Future  ....two coats. I think it was finger grease or similar. Ill try a touch up...if it doesnt work a sand down and repaint. All part of the fun :angry:  :ar:  :ar:  :ar:
Wow Dork that's some impressive paint work! Great job on the camo! As for the white stripe, I'd touch it up with a brush by hand. Should be pretty easy work.
Best of luck and keep us posted!
Dork the kit slayer
Quoteand keep us posted!
Big problem...bad workmanship really.  A combination of a small crack in the filling that let water under the paint and "Kleer" plus I used gloss white instead of my usual matt.....different thinning ratio and airbrush pressure...........a cock up just waiting to happen.  <_<  :angry:  <_<   I usually have good results using Shas's method of coating with kleer ,but bad filling and moisture...no excuse. Let that be a lesson to us all. :P  :P
Ill resand and prime  today and hopefully restore tomorrow....if Xmas shopping doesnt get in the way.
Quote....if Xmas shopping doesnt get in the way.
Ooohhh, are we going up to Preston again ??
Sorry, Al, sounds like you got the problem identified/solved, looking forward to seeing the little Fiat in the flesh sometime soon. Tell you what, bring it round here and we have a 'Model-In' sometime over the holidays.
K5054NZ
Mmmmmmmmm.........is anyone else in love with the Fiat G.50? I built Airfix's one and thought "Why aren't these still flying today?" I recently found out there's only one example left, and it is in (unrestored) storage in Belgrade. Sigh......
I just love your camo work so far (so does Lana - she adores Italian camo jobs) and like Brian said it'd be nice 'n' easy to just touch up the white by hand. But I;m sure that whatever you do it'll still turn out great!
Dork the kit slayer
Still not the best but this time I guess it will have to do. Im told that the spray pattern was very random and quality was very variable,so I may get away with it.
A lesson I did learn from this and Id like to pass on....is dont spray gloss white if the other paints are matt. The gloss gives a much "thicker coat". Ill be using my usual matt white and Kleer next time.
Im going to start the weathering and decals tonight. With luck the next time this is aired in public it will be completed.
While I was trying out the new airbrush I did a freehand paint job on this small 1:72 Corsair.  Does it need masking?? or do you think once its weathered and dirty this demarcation will work.  My fellow wiffers opinions are always gratefully recieved :cheers:
It looks like a wartime finish applied in the field to me...they didn't have the stencils and time to make them look like the factory jobs after repairs. I would leave it as is, and maybe do some weathering.
