avatar_overscan
Real Soviet Carrier Aircraft projects
Started by overscan, September 16, 2003, 12:42:49 PM
overscan
An-71 AEW aircraft
Beriev P-42 ASW aircraft
MiG-23A- First naval MiG-23 project
MiG-23K- Second naval MiG-23 project
"Typhoon": a project by the P-42 designer for a multipurpose combat aircraft
AEW version of "Typhoon"
Paul Martell-Mead / Overscan
"What if?" addict
Welcome aboard comrade overscan.  These plans will be of great use in our struggle with the imperialist facists!
Although I cannot help but feel that the Beriev P-42 ASW aicraft looks somehow familiar...
Joe C-P
If you build them, Comrades, I will find a place for them on our ship!  :D
Unfortunately, the shipping of MiG-23s and -27s appears to be delayed until December. Undoubtedly due to sabotage by imperialist Western agents fearful of our natural superiority!
Up the Revolution!  ;)
Comrade Iosef R
Comrade Joe,
Fear not for the lack of Mig 23's & 27's. The 'Lenin Rememberance' avaiton plant is just coming on stream and is completely unknow to the imperialist pigs and their dirty spies, and production is due to start shortly.
All that is needed now is for Comrade Tomski to produce the decal sheets of our glourious Red Banner Naval Aviation Ensigns that can be reverently painted on the sides of our glourious aircraft so they can sweep the capitalist/imperialist dogs from the seas.
All Glory to the Motherland
Comrade Colonel Lancerov
Davey B
QuoteI cannot help but feel that the Beriev P-42 ASW aicraft looks somehow familiar...
That, Comrade Nevski, is of course down to our glorious KGB agents ripping off designs for Capitalist Western kit. May they be eternally hailed for bringing us plans to the inferior Concorde!
Dosvedanya,
Commissar Bowlingov
Coolski !
I like that AEW Typhoon.....lumps and bumps and Wodka all around !
Toadarov
overscan
"Taifun" (Typhoon) was a project for a multipurpose carrier aircraft. 6 versions were planned, with two basic airframes. The first airframe (stressed to 7.5g, with low bypass ratio engines) was intended for ground attack, ECM and tanker versions. The second airframe (stressed to 5.5g, high bypass ratio engines) was intended for AEW&C, ASW, transport.
PROJECT " Taifun" Version 1 / Version 2
Length: 15.7m
Wingspan :16m / 19m
Wingspan(folded): 8.2m / 9.5m
Height: 5.2m / 5.5m
Wing area, 49.5 sq m / 58.9 sq m
Sweep angle: 27 deg / 20 deg
Standard takeoff weight: 22000kg / 23000kg
Empty weight: 14500kg / 15300kg
Standard fuel load: 5000kg
Combat load: 2500kg / 2700kg
Transporting load: 5500kg
Max Speed:  1070km/h / 760km/h
"What if?" addict
Joe C-P
Quote"Taifun" (Typhoon) was a project for a multipurpose carrier aircraft. 6 versions were planned, with two basic airframes. The first airframe (stressed to 7.5g, with low bypass ratio engines) was intended for ground attack, ECM and tanker versions. The second airframe (stressed to 5.5g, high bypass ratio engines) was intended for AEW&C, ASW, transport.
Very similar in size and shape to the decadent S-3 of the imperialist Western navies. Clearly they copied the work of our dedicated workers!
If someone builds this I can place it on the flight deck of the Sovietsky Soyuz.
That An-71 AEW is awesome! B) I'd love the challenge of duplicating it in miniature.
Up the Socialists!  ^_^
Comrade Iosef R
Deino
If You want to build this magnifi´cent project ... here are two interesting links for the kit from A-Model (AMONSTER 005: http://www.lindenhillimports.com/amodel.htm) or from "Russian Project":
http://www.flugzeugforum.de/forum/showthre...&highlight=An71
http://mysite.freeserve.com/aircraft_pages/an-71.htm
http://www.flankerman.fsnet.co.uk/an-71_modl.htm
Happy modelling  :rolleyes:  Deino  !!!
My noon, my midnight, my talk, my song;
I thought that love would last forever; I was wrong.
The stars are not wanted now; put out every one:
Pack up the moon and dismantle the sun;
Pour away the ocean and sweep up the woods:
For nothing now can ever come to any good.
W.H.Auden (1945
Joe C-P
QuoteMy project should be nearing the factory floor shortly, may I request the deadline date? :wub:
:ph34r: Gen. Vespernoliavich  B)
KGB
Fear not, Comrade Vespernoliavich!
There is no deadline. This project is ongoing, a glorious tribute to the continuing revolution and the constant struggle of the proletariat against the bourgueois.   ^_^
Also, the supply line to the fleet has been delayed, and we do not expect the completed planes to be loaded aboard the vessel before the end of this year.  :o
Our great ship, the Sovietsky Soyuz, will take aircraft aboard at any time, once I, Admiral Iosef R, have specifications and photos. It may take a while before the aircraft reaches the vessel, but I promise it will appear aboard.
Up the Revolution!!
B)
raymond
greetings
thanks for the news comrade joeP
my OKB's 23K will be ready for carrier deployment around the end of december, beginning of january. we have compleated test flights on S.01 and have finied out included updates.  these include a mig 29 style canopy and FLIR for bettr vision.
how are others going with fleet deployment status?
Mines still in the box.....but it's had lots of 'test fits', and could be completed before the end of the year.........but I still need somat to strap underneath....I could probably use anything, tho. But I'd like to have a Mig15 fuselage.
Cheers !
Ollie
Comrades!
The glorious workers under my just supervision have started to paint the La-15K.
The delay was caused by a bad batch of paint, which totally refused to cooperate!  The mixers at the refining plant were duly shot with a Makarov pistol.
We should get the colours done by the end of the week!
Za Stalina!
Za Rodina!
Major Olivienev Jakovitch Lacombski, SPD VVS (Special Projects Division)
KnAAPoOZQc plant deep in Trans-Siberia.......
raymond
QuoteThe delay was caused by a bad batch of paint, which totally refused to cooperate! The mixers at the refining plant were duly shot with a Makarov pistol.
Ah! so they struck you too!!! i am grealty pleased to hear that they have been handled according with standard party doctrine. this shoudl be exiting to have all hte aircraft being deployed at a similar time!
Deino
Quote"Typhoon": a project by the P-42 designer for a multipurpose combat aircraft
Hi overscan !!!   ... nice to meet You here !  :rolleyes:
Do You have any more information about this "Typhoon"-project ??? I've never heard about it until You posted these pivtures and even in the book where I found the P-42 it is not listed !?
Thanks in advance, Deino  :D
W.H.Auden (1945
