Ju87k-2t Stuka
Started by wolfik, January 19, 2007, 12:18:45 PM
A bit conventional maybe, but how about two MK 101 or 103 cannon pods under the wings?
PanzerWulff
#16
Or a Fritz-X maybe??? :unsure:
Hi folks,
For those who might be interested, here are a couple of possible German Anti-shipping weapons that might be suitable for this beauty:
Blohm und Voss Bv 143
The Bv 143 was a glide bomb for anti-ship use, accelerated by a rocket engine. It was a primitive sea-skimming missile. A feeler arm was designed to keep the Bv 143 about 2m above the water, but it did not work properly, and the missile was cancelled.
Blohm und Voss Bv 246 Hagelkorn
The Hagelkorn was an unpowered long-range glide bomb. It had an excellently streamlined fuselage, and wings with a very high aspect ratio. Construction of the wings was unusual: The aerofoils were made of concrete, around a steel core. Range was up to 200km if released from 10,000m. Several guidance systems were tried, including the Radieschen radar homing system. This made Hagelkorn one of the first anti-radar missiles. Over 1100 were produced before the project was cancelled.
(See above for more pics)
Blohm & Voss L.10 "Friedensengel" Torpedo Glider
The Friedensengel was a set of wings and tail surfaces, designed to extend the range of a standard 765kg air-launched torpedo. The onboard control system also freed the launch aircraft from the need to maintain the exact speed and altitude required by the torpedo. About 450 were produced.
Fritz-X
Fritz-X, also known as FX-1400, was the first successful guided bomb. It consisted of a 1400kg armour-piercing bomb, fitted with four wings in a cruciform arrangement, and a tail ring with spoilers for control. It was usually carried by specially equipped Do 217 or He 177 bombers. In the launch aircraft, an operator steered the bomb to its target using a radio command link. Two hits with Fritz-X sank the Italian battleship Roma. Others seriously damaged the Italia and the British battleship Warspite, sank the cruiser Spartan, and damaged the cruisers Savannah and Uganda. Production of Fritz-X was limited to about 1400.
Henschel Hs 293
This was the first guided missile that entered service in large numbers. The Hs 293 was a glide bomb of aeroplane configuration, with a underslung rocket engine. It was carried by bombers like the He 111, He 177, Do 217 or Fw 200. A radio command link was standard, and a flare in the tail burned to help the operator sighting. There were also versions with wire guidance, and the experimental Hs 293D had TV guidance. The sloop HMS Egret, on 27 August 1943, had the dubious honour of being the first ship sunk by a guided missile. Many other victims followed, including five destroyers. Over 2300 Hs 293 missiles were fired.
Henschel Hs 294
Derivative of the Hs 293. It was intended as a anti-ship weapon, travelling to final trajectory to its target underwater.
Henschel GT 1200
The GT 1200 was a powered glide bomb for use against ships. It was designed to dive into the water at the end of its trajectory.
Blohm & Voss Bv L.11 "Schneewittchen"
This was an improvement of Friedensengel. Few were delivered.
Zitteroschen
Zitteroschen was the first supersonic, winged, and guided missile. Intended for use against ground targets, it had small triangular wings and two rocket motors. It did not enter production.
BTW, many of these weapons are available in both 1/72 and 1/48th form.
Rafael
The works of an Architect!!!
The Sixtin Chapel of models!!!
Rafa
1/72 Scale Maniac
YOU - ME- EVERYONE.
WE MAY THINK DIFFERENTLY
BUT WE CAN LIVE TOGETHER
QuoteBeyond me!   :o   :wub:
If a master say this ... what can I say?
:wub:  :wub:  :wub:  :wub:  :wub:
You and I can both say "Please pass the next skein (of knitting wool)"   !!!!!!
I'm just as mesmerized and perplexed as anybody else when looking at Wolfik's uncanny ability to will plastic into shape.
QuoteI'm just as mesmerized and perplexed as anybody else when looking at Wolfik's uncanny ability to will plastic into shape.
I smell witchcraft at work here!!!
Leigh
Wolfik I'm always impressed by the quality and cleanliness of your conversions but what always blows me away is the wingfolds! any chance of a step by step how to?
Leigh's Models
Nice! I'm going to have to insist that you finish this model before you get distracted with another!
Fantastic!  As for markings, it is positively screaming at me - Italian Navy!!
Quotewhat always blows me away is the wingfolds! any chance of a step by step how to?
I second that request.
QuoteFantastic!  As for markings, it is positively screaming at me - Italian Navy!!
ooooh yes  :wub:
wolfik
hi all :)
many many thanks for the laudation  :wub:
I will follow your appeals and will make a small article how to make simple and non labor-intensive wing folds.
its easier as it looks ;)
thanks again!! :cheers:
peter
Any progress Wolfik?  If not but your still considering working on it, can I suggest (well actually P1127's idea from the Turreted Fighters thread) a turret maybe, like the Defiant?
did this ever get finished? :D  :D
