avatar_Radish
3-engined Aircraft Types.....
Started by Radish, January 22, 2007, 09:00:15 AM
QuoteHell Jon.
BdB would have to be in hog heaven with this thread.  When you said 3 engined 110, I was actually expecting one of the photoshopped jobbies from Unicraft's asymetric spinoff.
Any info on the wing engines?
regards,
John
Hi John,
the plan was for an unpowered wind-tunnel model.
But I suppose one could 'invent' a previously unknown small aero-engine developed by Porsche
using his Auto Union racer engines as the starting point.;)
Cheers, Jon
Archibald
Couzinet made many aircrafts with three engines... most famous is the Arc-en-ciel (rainbow) but there was plenty others.
don't forget the Dewoitine D-332 and D-338!!!
Aviafrance  :wub:
http://www.aviafrance.com/aviafrance1.php?...SION=0&MOTCLEF=
http://www.aviafrance.com/aviafrance1.php?...UCTEUR&MOTCLEF=
http://www.aviafrance.com/image.php?im=322
QuoteWasn't there a version of one of the early Northrop monoplanes with three Curtiss Conqueror engines?
Hi Evan,
Jackie Cochran's Gamma 2G, s/n 11, was powered by a Curtiss Conqueror and was the only Gamma
powered by an inline engine.
Her aircraft was later re-engined with a radial and was the aircraft Howard Hughes used to set the transcontinental speed record in 1936.
I've not seen pictures or read reference to an early  Northrop tri-motor. The Alpha, Gamma, and Delta series of aircraft were not large enough to safley mount three Conquerors.
Cheers, Jon
A Junkers project for a large doppel-decker trimotor:
Length around 35m, wingspan around 44.5m. Powerplants unknown, Jumo 213 could be a possibility as a Ju 52 was modified with one 213 mounted in the nose.
The Arado was to use four Jumo 208 Diesel engines, two per nacelle.
Cheers, Jon
elmayerle
Hi Evan,
Could be, it's been ages since I looked through Rolfe's book, which is where ISTR seeing that.
For a touch newer, if hardly modern looking, effort, there's the Northrop C-125 "Raider".
--Jane Wagner and Lily Tomlin
QuoteConroy Tri-Turbo-Three, a small number of DC-3's converted to turbo props with one engine in the nose.
http://www.apda61.dsl.pipex.com/Av5/Conroy.jpg
http://www.air-and-space.com/conroy.htm
Fantastic!!!  :o  I've never heard about this before... turboprop DC-3s  :wub:  :wub:  (love the one with the 3 *PT-6A)
Archie, Heritage Aviation do a Turbo-Dak conversion in 1/72:
http://www.heritageaviationmodelsltd.com/B...0Dak%20Inst.JPG
I got one a while ago and started to build the model but that was before my house move.  It's on hold for a while until I get my model room fixed up and running.  It's a very neat conversion and you get the forward fuselage plug that the Baslers get to correct the cg.  There's decals and parts for a South African AEW Trainer version too.
Robert
