Main Menu
avatar_ysi_maniac
Stardelta
Started by ysi_maniac, February 22, 2007, 12:09:26 PM
A 4 mm gap that need filling
Second inaccuracy, the engine looks up
I made two cuts in adequate angle. Then I flipped this section 180 degrees "et voila". As an extra side efect the brakes now are above the root of intended wing, so I can keep them.
SPINNERS
Looking good! Very inventive.
This sure is looking the part  B)
But what is the deal with that Banana fuselage????  :blink:  :blink:
Great modifications, are you going to make a canopy or do you have one the right size?
QuoteBut what is the deal with that Banana fuselage????  :blink:  :blink:
I made two cuts perpendicularly to the fuselage axis, but these cuts were not (just a few degrees angled) parallel. Then I turned 180 degrees the section between these cuts, so up is in down and left is in right, but front is still in front. I will try to post a drawing.
Carlos. :)
Cool Ysi! If only i had the skills to do that great a conversion!
What will you do with the canopy?
Surgery with clear parts is a difficult task that I have not practised yet :wacko:
But ... stay tuned. :)
Rafael
Well, Doctor Carlos, your surgical skills so far impress me..... :wub:  :wub:  :wub:
Keep up the great work on this great model!!!!
Me encanta!!!!
Rafa
1/72 Scale Maniac
YOU - ME- EVERYONE.
WE MAY THINK DIFFERENTLY
BUT WE CAN LIVE TOGETHER
Carlos. :)
no, no, no, I meant hth did they manage to make (and sell) a kit like that!?!
Maybe it was the "Banana Republic Export Version"? :lol:
Ok, I'll go back in my hole now...
Open your door and go out on your doorstep.
Listen carefully.
That distant but clearly wild sound you hear is a Canadian cheering for you with unbridled enthusiasm!
Terrific!!!  Bold, daring, and well-executed, too.
Love the fuselage trick: like the way tin-bashers twist furnace vent pipes.  Clever!
Carlos that is a innovative approach to correcting the fuselage! My hat is off to your incredible skill.
