avatar_Damian2
Usaf Au-1
Started by Damian2, March 07, 2007, 01:02:25 PM
Quoteand a VERY badly warped GR.3 fuselage
More like crushed!  I think it happened after I moved out of my parents, a bunch of models were still in the loft & my Mum was having a clear out.  She saved them (you never know when my Mum gets in clean-up mode!) but they were firmly sqaushed into a single box.  Luckily, they all survived apart from the GR.3, which took the brunt of the squashing, throwing about & then transport to my house.  Glad it's of it use though Damian!
Looking forward to seeing more work on this bomb-sair!
Jeffry Fontaine
Like what you are doing with that Corsair.  Have one suggestion to make.  Don't use the triple ejector rack and stick with single weapons on each pylon.  There is not a lot of room on the underside of the aircraft and any weapon that is not ejected downwards from the aircraft is subject to banging into something next to it and you have a very crowded underside as it is.  Overall your weapons load out is practical and with the exception of the TER you are looking very beliveable.
What kit provided the weapons pylons for your wing stations?
Damian2
QuoteLike what you are doing with that Corsair.  Have one suggestion to make.  Don't use the triple ejector rack and stick with single weapons on each pylon.  There is not a lot of room on the underside of the aircraft and any weapon that is not ejected downwards from the aircraft is subject to banging into something next to it and you have a very crowded underside as it is.  Overall your weapons load out is practical and with the exception of the TER you are looking very beliveable.
Thanks fro the input Jeff! I think I may go with Naplam on the fuselage mount as thats a pretty good area effect (affect? ah who cares!) weapon and nix the TER.
As for the pylons they are provided in the 1/48 Hasegawa AU-1 and F4U-7 versions of the Corsair. I got the AU-1 boxing with the gull grey over white "Quantico" markings...
Damian2
Here's the pics of my recent work :)
the underside...
my pre-shading
rolling in...
some of the completed weapons
Impressive work on those weapons, D2! I really like your concept!
Although I have never seen a Corsair I didn't like, I would NOT want to be an enemy on the ground with YOURS flying overhead-------yikes!!!   :unsure:
