What If The Usaf Got Tigercats?
Started by famvburg, March 15, 2007, 06:43:26 PM
On the subject of the Tigercat a couple of real-world Grumman projects:
Torpedo Bomber
Jet Nightfighter
Also the XP-65 as conceived was to have turbo-supercharged engines and two 37mm cannon in the nose.
Cheers, Jon
Excalibur
They look so right in the SEA scheme, really aggressive. Well done.  :cheers:
Jschmus
That Design 75 looks a little like the Curtiss XP-87:
XP-87
famvburg
QuoteActually, I think a turbo prop would make more "sense" - a twin jet Tigercat would have pretty short legs, even with the wingtip tanks. The IL-28 nacelles are handy because they also include the main landing gear.
I can't think of any good cheap, turboprop donor kits, though.
I can't think of any cheap turboprop donor kits either - but using the IL-28 nacelles and Wyvern props would work.  The other alternative would be to scratch-up a set of "Trent-Meteor" props.  Both approaches would, IMHO, work nicely with that nacelle.
     I have an old P-3 kit I plan to use the engines & props off of for a Turbo Tiger & a couple of other things. I would think the old Airfix/MPC C-130 could be found pretty cheap, if you want that kind of cowling. A cheap source for two TPs, if you want RR Darts would be the Handley Page Dart Herald kit from some European maker. It's the old Frog kit. I've considered them, but I just like the look of the Allison in the P-3 type cowling. I used old Airfix C-130 engines & props for my A-26 Turbo Invader & Turbo Skyraider (C-130 for USAF A-1K(H/J) & P-3 for USN A-1L(E)). Maybe an older Hasegawa Shin-Miewa could be gotten cheap enough as well. It uses GEs, IIRC.
frank2056
QuoteA cheap source for two TPs, if you want RR Darts would be the Handley Page Dart Herald kit from some European maker. It's the old Frog kit. I've considered them, but I just like the look of the Allison in the P-3 type cowling.
Of the three that you mentioned, the Handley Page Dart Herald is the cheapest. That kit has plenty of whiffiness to it, too!
