N
Hawker P.1154
Started by Nigel Bunker, August 22, 2002, 06:03:10 AM
Quote from: Howard of Effingham on July 29, 2013, 03:05:40 AM
thanks gondor.
my freightdog P1154 gets a USMC finish now.
If you check the SIG notes in the Downloads, you should find a reference to the USN looking at the AV-8C for Carrier Close support for when they are unable to use CATOBAR aircraft such as near port.
Also in BSP the USN were going to be a customer for AV-16.
Gives you a different option fo the usual DSG/DG scheme
If you're dead set on USMC, there was at least one AV-8A painted up in a winter scheme:
What are the blunt nosed objects that it's carrying on the wing pylons?  Drop tanks or Napalm bombs?
Napalm.  Think they're BLU-27 with the nose and tail caps removed.
