avatar_Radish
The 500 Phantom Group Build
Started by Radish, May 14, 2007, 03:22:04 AM
How about the proposed F-4E(F) single seat variant of the Phantom - see here for details.
Martin H
QuoteHow about the proposed F-4E(F) single seat variant of the Phantom - see here for details.
did that one ages ago
Its safe and sound in the sigs display at the Midland air museum, coventry
Along with an F-4HL
Hey ted im still going to do the Slip wing idea of yours...just a small matter of clearing the bench of VTOL builds first
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
Quotedid that one ages ago
Any pics - given that the the Midland air museum is a little out of my way right now.
Radish
And the F-4T was a stripped-down "E" proposal....also single-seat I believe. :D
Radish
Wow!!!!
When I went into this I NEVER realised the possibilities...and more to come.
I've sorted out 20 different colour schemes (ie COLOURS not unit markings, etc)
One colour scheme....the basic low-viz grey that's everyone's favourite :lol:  :lol:  has around 10 models allocated to it already, mostly real but some whatiffy ones too.
Other candidates are:
Desert Pink....111 Sqn RAF
White....dirty and Finnish
NATO grey/green/PR Blue...Belgian
Black....Saudi
Sand, grey, brown....Pakistan
Sand/charcoal....Algeria
Oooooohhh, so many.
2 x F-4S sprayed in grey already.
RF-4E awaiting an u/c......Desert Pink?? :rolleyes:
Daryl J.
Radish,
How about taking a Fujimi F-4J and shortening the vertical stab's chord a tad, removing the dog tooth on the outer wings, flattening the horizontal stabs a mite, converting it to single seat, and painting it the dual green scheme seen on on Harriers (NATO/Lichen green?) and hanging a dabble of Rockeyes on a couple of pylons?
Daryl J.
Radish
Fujimi "J"s will be built real, but Italeri "S"s are cheaper and easier to come by.
I'll certainly be adding some whatiffery, not just in the paintwork...
I quite fancy a zwilling F-4SS?? Black and silver :ph34r:
And that modelling feat could release a couple of tailplanes for an X-tail Phantom :wacko:
And did I say that in The Rocky Horror Show there are Phantoms in the cast? :party:
Martin H
QuoteI quite fancy a zwilling F-4SS?? Black and silver :ph34r:
Hey terry that would look good alongside that Falklands based twin toom i did a few years ago
Unfortunately,
Radish
Sounds good, Martin.
Hey, a quad Phantom? Would it be a 4x4 :lol:
Rhino1953
I got my work in progress F-4M (gun armed Spey engined, 56 Sqn slatted blah blah blah) out last night with a view to finally completing it, but the main gear has disappeared and there is other damage to it, so I've put it away again. I'm going to have to find an Aeroclub U/C set to replace the broken bits, then I'll continue from there. The plan was to complete it for the Tyne and Wear show.
Oh well, thats life.
USAF SIG
F-4 Phantom SIG Leader
www.500phantoms.com
So 500 Phantom build - can you do the origional McD Phantom ? Or does it have to be the II ?
Radish
It's all to do with the 50th Anniversary of the F-4 Phantom II so the early Phantom might not be applicable, but I'm only entering, not applying the rules.
There's also the very early Phantom II projects which look a bit like a cross between a Demon and the end result.
Single-seaters again. :party:
Rhino1953
QuoteSo 500 Phantom build - can you do the origional McD Phantom ? Or does it have to be the II ?
Sorry, it's specifically the F-4, as that is the anniversary we're celebrating, although we had discussed the original Phantom within the SIG and decided against it.
Ted
USAF SIG
www.500phantoms.com
elmayerle
Okay, if you can find a conversion for the original "low canopy" F-4A, how about using that as a basis for a single-seater with the back portion clear to improve pilot visibility?  It could be with or without internal gun.  I admit to being tempted, very, to try doing that one.
--Jane Wagner and Lily Tomlin
Radish
That's a very interesting scenario...mmmmmmm.  :blink:  :cheers:
