Floatplane F-6f Or Firefly?
Started by Lawman, June 29, 2007, 03:23:52 PM
QuoteYou know what we french say "il n'y a que les imbéciles qui ne changent pas d'avis" (= only idiots never change their minds ;) )
So a reasonable choice would be 1/48 scale Beaver floats ? Is there others aircrafts which have floats close in size from a Beaver ?
I was looking at all up weights of the Spad again and the scout version is about 13,500 lbs which puts it in the same ball park as an Antonov An-2, and you can buy a 1/72 An-2 on floats:
http://www.hannants.co.uk/search/?FULL=TU01606
Or there's this conversion for a 1/48 Wildcat floatplane
http://www.hannants.co.uk/search/?FULL=CEC48090
PanzerWulff
QuoteOr there's this conversion for a 1/48 Wildcat floatplane
You mean this one
Continued............
PanzerWulff
And Pics of the real thing
"Panzer"
Archibald
Merci very much!!  :cheers:
Is that your model Panzer?  Very nicely done :wub:
Archibald
Just a question (sorry for the off-topic)
Is it just me, or does Hannants refuse to send anything below a 30 pounds order ? Imean, until you haven't reached  a 30 pound order, they can't send anything to you ?  (I understood its because of packaging costs...)
QuoteJust a question (sorry for the off-topic)
That's about it Archie,  it's the only thing I don't like about Hannants
I like the Skyraider SAR concept, but why bother with twin floats and struts etc?  Why not go for something along the lines of the Grumman J2F/OA-12 Duck:
This sort of robust float would be just the thing on a SAR Skyraider - at leats that's what I think.
BTW, there are a number of kits (in various scales) of the Duck available in case you want to use it for parts.
With the 'boxy' sides of the Spad it might just work too.  With a float about 3'-6" wide it would have to be about 55 feet long, there abouts.
PanzerWulff
#24
QuoteIs that your model Panzer?  Very nicely done :wub:
I Wish!!! :P I found the pics and the write up on the conversion online after searching F4F-3S Wildcatfish Which was the nickname of the actual aircraft
Columbia XJL-1:
Wing Span:  50'
Length: 45' 11"
Height: 16'
Weight:   13,000 lbs (loaded)
Maximum Speed:    119 mph
Engines: 1 Wright R-1820-56 (original) - 1 Wright R-2600 (refit in 1960s)
Crew:    2 (6 passengers when used for Air-Sea Rescue)
and for comparison.
Douglas AD-6/A-1H
Wing Span: 50'
Length:   38' 10"
Height:   15' 8"
Empty Weight: 11,968 lb
Gross Weight: 18,106 lb
Max Weight: 25,000 lb
Cheers, Jon
elmayerle
QuoteI've finally decided that it would be another T-56 Skyraider  ;)  4900 hp sounds enough, and floats would coolness to the design...  :wub:
Got another idea... while building my Skyraider I've noticed a kind of "door" between the wings and below the fuselage. This Skyraider on floats will be a SAR machine. I could use this door as a compartement for the lost pilots picked up in the water... then I could dig two windows (instead of the airbrakes) on the side of the fuselage... a three-seat Skyraider!  :wacko:
Hmmm R-4360 Skyraider sounds like Martin AM-1 Mauler for me  ;)  Cool idea!
We are currently building a whole lineage of Spads... R-3350, R-4360, Skyshark (= XT-38) then my T-56 machine...
I'm surprised no one's played with a Martin Mercury, the proposed COD version of the Mauler, as a SAR bird. :D
--Jane Wagner and Lily Tomlin
Archibald
#27
I remember seeing some pics of this project... you're right, such machine on floats would be an impressive SAR aircraft... in fact it would truly be  a scaled-up Beaver!  :o
A Skyraider with the "duck" treatment would be something, but beware of propeller clearance with the central float...
PanzerWulff
#28
HMMMMMM how about slightly shorter blades but a Contra rotating prop to deal with Archies Prop clearence observation???
That XJL-1 reminds me sort of a AT-6 Texan on floats
"Panzer"
Of course, the USN & others operated this one in modest numbers:
WIP!
And don't forget Baz's:
http://www.whatifmodelers.com/forum//index...ic=14853&st=45&
