avatar_ysi_maniac
Rdf Skyraider
Started by ysi_maniac, July 10, 2007, 05:58:09 AM
Hi Evan and Simon,
Thanks a lot for your help.
Stay tuned
:cheers:  :thumbsup:  :cheers:  :thumbsup:
Shasper
If the radial give the req. power & isnt too heavy, why not?
Shas B)
- Bud S.
And prop blades: rounded, squared, scimitar shape ?
Assuming turboprop or piston.
Thanks
QuoteIf the radial give the req. power & isnt too heavy, why not?
Shas B)
And upgrade to Turbocompound  :wub:  :unsure:  :wub:  :unsure:
elmayerle
Shas B)
Emm, I'd probably try to avoid extra complexity in the engine installation and not go the turbo-compound route; just that much less to take battle damage at a critical moment.  If the existing radial, or a more powerful version of that engine, works, I'd be inclined to leave well enough alone.
HTH,
Evan
--Jane Wagner and Lily Tomlin
Howard of Effingham
would one of those late WW2 or early postwar big fat mammas of a radial engine
work?
i can't recall the hp rating of the usual skyraider/ able dog engine but weren't there
some radials with a hp rating of say 3350hp and more without turbocompounding
but with turbocharging?
Keeper of George the Cat.
elmayerle
Developed R3350s had 3500hp ratings, if you want more in a developed radial, you have to step up to the R4360 which is going to need a rather longer cowl and will impact your all-up useful weight and cg.  At the  high-power end, there's not much option with radials.  I'd be tempted to go with the most powerful non-compound r3350 available, or look into the mods for a suitable turboprop.
An update:
You can see and comment the hipersustentation surfaces in wing's trailing edges.
Wing apan han been increased. These two features in order to improve STOL performance.
The "boxes" in fuselage sides are devices intended to reduce noise and thermal signature. This leads to a redesign of whole cooling system.
BTW: the device with tubes under the plane is the RATO pack that will be attached in airframe's belly.
Very interesting Ysi! I'm very impressed by your RATO pack. That's some fine scratchbuilding!
Looking good.
Very interesting.
So what normally went in that big ole space where the spec ops boys are now?
It depends on the version. See HoE's post in the first page of this thread
Archibald
QuoteThe "boxes" in fuselage sides are devices intended to reduce noise and thermal signature. This leads to a redesign of whole cooling system.
Fantastic!
OK, last update before paintshop
