avatar_TsrJoe
Flying Saucers and UFOs
Started by TsrJoe, August 02, 2007, 04:08:38 AM
Sisko
In the Judge Dredd comic during the apocalypse war story the Sovs had a flying V shaped thing.
About 20 years ago I had a crack at building it but I just did not have the skills.
Think I might have to give a go again.
Judge Dredd I am the law!!!!!!!!! :ph34r:
Get this Cheese to sick bay!
TsrJoe
#31
some from yesterdays tinkering...
Fictional 'Sack AS.7' (Me.163), AS. 8' (Me.262) from Ted Nomura's 'Luftwaffe 46' comic, Antarctic Press, 2001
iv seen mention to a 'disc winged' Me.109 too turning up online in recent years but never seen any artists impressions of it ??? (im guesing a bigger version of the Argus engined Sack AS.5 would probably do?)
cheers, Joe
The Argus engined machine was the AS.6, the AS.5 was the flying model that preceded it.  As far as I know, the AS.7 would have been the saucer winged Bf-109, & would probably have been known as the Me-600.  The AS.7 would probably been based on a 109K, with a DB605 & four blade prop, the K models Galland hood & six cannon in the wing.
http://www.luft46.com/misc/sackas6.html
http://en.wikipedia.org/wiki/Arthur_Sack_A...tt_600_proposal
I found the same pics as Gary, apparently the guy tried to work out how the AS.7 may have looked using the X-Plane flight sim software, apparently it has a good physicis model & is good for creating project & fictional aircraft.  He came up with an aircraft with a short rear fuselage & T-tail after experimentig a bit woth the flight model.  He also included the AS.8 design Gary posted with push-pull props.  I think that this was his own idea rather than a real project, he used the pusher prop to counteract torque problems he found in his AS.7 flight model.
Sack AS.7/Me-600:
http://www.sunlight.de/x-plane/jbx/as7.htm
Sack AS.8:
[/IMG]
http://www.sunlight.de/x-plane/jbx/as8.htm
PS, These saucers of yours are turning out great Joe, keep up the good work! :thumbsup:
QuotePS, These saucers of yours are turning out great Joe, keep up the good work! :thumbsup:
Agreed!
frank2056
QuoteI found the same pics as Gary, apparently the guy tried to work how the AS.7 may have looked using the X-Plane flight sim software, apparently it has a good physicis model & is good for creating project & fictional aircraft.
X-Plane is indeed a great way to mock up and test fly real or imagined airplanes. I made a model of the Focke-Wulf 1000x1000x1000b and even with the listed engine thrust, it was easy to fly and very responsive. I even played with no winglets, upturned winglets and different engines. The winglets helped with yaw stability.
Based on the poor performance of the Sack AS6, I always thought of it as A Sack of... Shitakke.
Frank
TsrJoe
B) arrived in the post this morning, the 'Fantastic Plastic' '40ft Flying Saucer' beautiful moulding and looks like itll be an easy build too ...
http://www.fantastic-plastic.com/USAFFlyin...taloguePage.htm
http://www.ufowisconsin.com/news/n2003_02x...ersforreal.html
http://www.ufowisconsin.com/news/flyingsaucers.html
That's a beast Joe!  So Unicraft's & Sharkit's Avro flying dics after this one eh???
http://www.lonewulfmodels.co.uk/search.php...x=15&Submit.y=8
TsrJoe
one my dad found from his younger days whilst sorting through some old papers ... (the best part is that he's also found a box full of old 'Jetex' solid fuel rockets too, pellets, igniters, fuses, etc. ... hehehe!)
TsrJoe
... after a modelling hiatus, i thought id make a start on some posponed projects ..
... just finished priming the Me.163 and 262 saucers, i think ill just go with standard late war schemes to finish
... started working on 109 derived saucer to complete the family based on the posted artwork here
... the 'Fantastic Plastic' saucer has been assembled, filled and primed and awaits final painting, again ill prob be pretty boring and give it an overall silver scheme
... having vacformed a few spare mouldings of saucer shapes, iv been tinkering with the idea of adding aircraft cockpits, empennage, etc to the disc form to se what develops..ill post up some images of my musings (a Harrier saucer actually looks not too bad too..lol)
cheers, Joe  :wacko:
Jeffry Fontaine
The As-8 with the tractor/pusher set up has me wondering what a Do-335 would look like with the disc wing.
TsrJoe
TsrJoe
Any of these projects going to be entered in the Flying Sorcery GB Joe???
Jeffry Fontaine
Joe,
Did you ever consider a cargo saucer?  Perhaps a kit bash with a C-130 or C-119 to create a saucer freighter?
Well, the Naranjero was built to ship oranges, maybe this one could ship tomatoes?  Tomato saucer.....
I'll get me coat.
