Main Menu
Ltp
Started by wolfik, August 15, 2007, 01:43:31 AM
wolfik
Ltp
hi all
the idea was to design a landing vehicle from existing tank parts...
the first idea was to use a M18 and let it swimm...
the second idea was...to use finally my tamyia stuarts buyed for 6$ each
I buyed some of these during an exhibition and 4 are definitely to much...
I made some drawings (posted below) and started to cut the hulls.
after three nights it looks not bad for me <_<
it was my attempt to construct a vehicle which could be designed before and produced quickly after pearl harbour using mass produced parts of existing tanks.
as you can see the finished project differs "marginal" from the oryginal sketches
but...as I sayed before...two more stuarts are in the stash... B)
hope you like it...
I want finish it to an exhibition in september of which the guiding theme are LVT´s
I made some moulds to make the work easier and to save time...
the work continues
Peter
wolfik
other drawing....
I decided ...the slant plates would be to time consumpting during "production"...
wolfik
the work begins
wolfik
Ltp
#3
some advance...
the oryginal idea scheduled plan body plates...but...you see :blink:
double sided tape was used to make  side templates
wolfik
Ltp
#4
finished to this stage...
decided to design my own 75mm howitzer turret because I will made another vehicle build strict to my oryginal idea...
it will be equiped with the M5 turret
this one is now my "late" version of the LTP (Landing Tracked Personnel) with a big rear ramp and swinging water propellors (from an ESCI LAV-25)
wolfik
wolfik
Ltp
#6
the two turrets are from earlier project ...simply made mould of it and other usable stuart parts saved much time in the second night :zzz:
wolfik
Ltp
#7
view from above
seable are the repositionned turrets...
wolfik
Ltp
#8
side view
the engines are two Cadillac V.8 each powering one drive sprocket positionned higher like a MOORLAUFWERK seen on Caterpillars...sorry...was not able to find the english word for "marshy ground running gear" :banghead:
wolfik
Ltp
#9
front comparison with the LVT-(A)4
...do you mean I hit it (to) big? :blink:
its nearly so high like the LVT but from the perspective it looks bigger...
wolfik
Ltp
#10
last for today...the side comparison...
hope you like the show :cheers:
wolfik
oh!...other idea during buildin g was to install this "modified" Hellcat turret .
it was oryginally designed for the swimming hellcat.
something like a PT-76 but for the final stage of WW2
wolfik
Ltp
#12
the idea for the M18 turret was stolen from this M36 turret (italeri) made from a photo in a concord book
Maverick
Bugger me Wolfik, it's brilliant!!!  Can't wait to see this finished!!   :wub:  :wub:  :wub:  :cheers:  :cheers:  :cheers:  :bow:  :bow:  :bow:
HOG
Extremely interesting.
Slab sides,modelling in straight lines.
Might be tempted away from aircraft,
Please keep us posted as to developements.
Gary [8-]
(Ralph Waldo Emerson )
