Main Menu
avatar_ysi_maniac
A-16
Started by ysi_maniac, September 06, 2007, 06:09:46 AM
I have made some changes in this Academy YF-16 to give birth to this lightly downgraded version of F-16, intended to ground attack role:
No interception radar
PW 1120 powered
bigger wings to allow 2 additional hardpoints
Now the problem of the gun. I am thinking in Oerlikon KCA (the gun of Jaktviggen JA-37):
Installation in same position as original Vulcan looks OK to me, but I think that I should add a bulk, like a cft.
Having only one gun in one side, will it be unbalanced? perhaps no more than F-16?
Please, your comments
more
RP1
Interesting - is the nose going to accommodate an optical or laser device for operating PGMs?
Also, if this is in a cold war context, this might be a good anti-helicopter platform, with an IRST and ASRAAM.
RP1
"Just your standard-issue big gun."
- Batou, Ghost in the Shell
RP1 dot net
My Facebook
Very good ideas. :thumbsup: Thanks a lot.
A-10 gun in a centerline Drop Tank?
^^^^ Trials on this option were not satisfactory: http://www.f-16.net/f-16_versions_article18.html
Thanks.
Shasper
Try a 25mm or 27mm weapon as oppose to a 30mm gun, the side effects wouldnt be as hazardous. ;)
Shas B)
- Bud S.
AeroplaneDriver
#8
One idea I've been toying with for a long-planned modern COIN Mustang is cannon pods in the wings like the installation on the Do335 (Model and pics on ARC by Timothy Barnhart).
Take a couple of appropriate drop tanks and cut a horizontal slit so they slide onto the leading edge of the wing, maybe around 1/3 span.  Fair them in with putty/milliput/gum/your filler of choice.  The tanks make for larger pods than the Dornier, and allow for more ammo storage.  Add a spiffy cannon barrel of appropriate calibre and bingo you have a pair of guns for strafing all and sundry.
I think this setup would work on an A-16.  It allows two guns without taking up any internal space, allowing the area currently occupied by the M61 to be used for fuel, avionics, or even a toilet (for 777  ;)  ), and there are no issues with gas ingestion.  The lengthened wingspan also helps compensate for the loss of lift.
blue520
#9
Hear is a  daft idea, but why not two guns one on each side?
It would no longer would be unbalanced.
^^^^ too heavy maybe?
But cool B)  B)
QuoteTry a 25mm or 27mm weapon as oppose to a 30mm gun, the side effects wouldnt be as hazardous. ;)
Shas B)
Bushmaster gun, for instance?
Personally, i would think that wingtip maverics would make it cool! And a toilet of course :P
I've got to vote for the cannon pods! Surely very heavy guns are a necessity for a serious attack aircraft!
fabe
The conversion work you have done so far is really impeccable! Are you going to do a US version? Without radar and with enhanced ground-attack capabilities it could very well have become a "new F-5" which gets exported to less reliable allies.  :f16:
ALL ANIMALS ARE EQUAL, BUT SOME ANIMALS ARE MORE EQUAL THAN OTHERS
