Valom Models
Started by Maverick, September 06, 2007, 02:04:12 PM
Quote from: Mossie on May 22, 2014, 03:30:10 AM
I've got one boxing of Valom's Airacuda, the YFM-1B.  It's not bad, some of the details like the exhaust a bit chunky, not much interior detail but panel lines look good.  I've not built it, but I've test fitted some of the parts and fit looks reasonable, with a fair bit of PSR likely to be required but not extensive.
It seems like it's one of those 'needs a bit of work but worth the effort' kits.  Here's a link to a build:
http://www.britmodeller.com/forums/index.php?/topic/234925403-bell-yfm-1-airacuda-172-valom/
"exhaust a bit chunky"?? Try completely and utterly wrong. The exhaust plumbing
was under the skin in all models, turbo or not. I've one partially built in an ongoing build
and correcting the exhaust is the biggest headache.  :banghead:  :banghead:
Quote from: zenrat on December 13, 2014, 06:59:33 PM
Our spiders are too large.
Do you not sleep?
It's not whether I sleep but when....
Right now, 10.22am, just got up an hour ago, I could sleep..... :rolleyes:
I did some research on sleeping a while ago when Fat Hamsters daughter was flirting with polyphasic sleeping.
I found out that the human body functions best when having two sleep periods a day.
In other words siesta is where it's at.
The funky prop looks pretty neat. And the last one comes with a special racing canopy !
A RACING An-2??  :o
They HAVE to be kidding...........
Quote from: zenrat on December 12, 2014, 05:56:35 PM
Quote from: Thorvic on October 05, 2014, 10:43:51 PM
The Bristol Bombay has also been refreshed in the Future release on Hannants and Valom so perhaps its finally due out soon.
HLJ says Jan 2015 release.  So expect to actually see one in June.
http://www.hlj.com/product/VALCV72056/Air
Didn't bet any money on that did you?  :wacko:
http://www.hannants.co.uk/product/VAL72056
http://www.hannants.co.uk/product/VAL72097
Bugger me.  Accurate predictions.
That's crying out for the inner nacelles from a Lanc to give it Merlins and retracting wheels.
I will get the Mid East version for a real world build  :thumbsup: Probably at Hudders
Quote from: NARSES2 on January 11, 2015, 03:59:11 AM
The German (approximate) equivalent of the Bombay is the little-known Junkers Ju53 (http://www.whatifmodelers.com/index.php/topic,33915.msg534632.html#msg534632).  I can see this being Anglicised at some point.
Quote from: zenrat on January 11, 2015, 02:45:21 AM
I like that idea. :thumbsup: Hercules radials from the Mk.II or a Halifax would be even better! And would confuse a lot of people no end.... ;D
Bristol proposed the Type 144, which was to use the wing, forward and rear fuselage and empennage of the Type 130 'Bombay', a new center section with under the floor bomb carriage, and retractable undercarriage. Pegasus engines were retained. The description is in
the Putnam on Bristol, no drawings.
Valom Avro 618 "Tens" going for £15 (down from £37) at Hannants:
http://www.hannants.co.uk/product/VAL72039
That Bombay sure looks good....Love to build one or two of those !
I'll be able to tell you how well it goes together in the next week or two
