avatar_ysi_maniac
Super Viggen
Started by ysi_maniac, September 21, 2007, 08:07:28 AM
Based on ideas expresed in other thread: http://www.whatifmodelers.com/forum//index...16399&hl=viggen
... well tail fin have changed and nose is even longer: in the event, Gripen's proposed tail fin had swept trailing edge.
Thinking in F110 http://en.wikipedia.org/wiki/General_Electric_F110
What can I do with slots in aft fuselage?
Close them / split them to make fresh air inlets / ...
Archibald
It already promise much!  :cheers:
Already looks different to the standard Viggen Carlos, I'm sure the end result will be great!  Personally, I'd fill the reverse thrust slots, since it wouldn't be compatible with the F110 & you'd probably not need it as I assume the new version would improve on the STOL characteristics.  Which kit are you using, the old Airfix version?  Looks like it with the flat spine, but it's a long time since I built it!  And what kit is the forward fuselage from?
Damm Carlos, that is turning out to be one seriously good loking aircraft.
Deino
...or maybe something like that !!
My noon, my midnight, my talk, my song;
I thought that love would last forever; I was wrong.
The stars are not wanted now; put out every one:
Pack up the moon and dismantle the sun;
Pour away the ocean and sweep up the woods:
For nothing now can ever come to any good.
W.H.Auden (1945
McGreig
Looks great, even at this early stage  :thumbsup:
Looking great, Ysi! You really are a Kit Surgeon, 1st Class!
Archibald
QuoteAlready looks different to the standard Viggen Carlos, I'm sure the end result will be great!  Personally, I'd fill the reverse thrust slots, since it wouldn't be compatible with the F110 & you'd probably not need it as I assume the new version would improve on the STOL characteristics.  Which kit are you using, the old Airfix version?  Looks like it with the flat spine, but it's a long time since I built it!  And what kit is the forward fuselage from?
... and what wings do you plan ?
QuotePersonally, I'd fill the reverse thrust slots, since it wouldn't be compatible with the F110 & you'd probably not need it as I assume the new version would improve on the STOL characteristics.  Which kit are you using, the old Airfix version?  Looks like it with the flat spine, but it's a long time since I built it!  And what kit is the forward fuselage from?
yes, it is old airfix model. Front fuselage comes from a minicraft F-18: I took away lerx and introduced wedges to deepen up to required size.
anthonyp
This is gonna be cool!  Looking good, so far!
I exist to pi$$ others off!!!
