avatar_ysi_maniac
Hispano Aviación Ha-350 Dardo (dart) FINISHED
Started by ysi_maniac, October 18, 2007, 11:39:56 AM
Wow, you're like Thorvic's long lost brother  :P
QuoteNow, some questions about engine:
I am thinking in equipping it with dry RR Avon
Would it fit? Tumansky R-11 906 mm diameter, Avon 1050 mm diameter. Airfix model is a little oversized anyway.
Could a dry Avon be supersonic? Supercruise in 60s?
Well, you are being very kind with your comments; but I still need some help from you, knowledgeable sirs. So, I repeat my question ^^^^.
wolfik
looks like it will be a nice one...
like kitbashing and this one is not easy...
go ahead! :cheers:
Carlos, from your plans there seems to be an area rule bulge at the rear of the fuselage so I think you should be able to get an Avon in there with a little squeeze at each end.  As for supercruise, I'm not really the person to answer your question, but I'd say it's just about possible.  The Lightning could supercruise, although it had two Avons.  The Draken with more advanced aerodynamics & it's single Avon could go supersonic very easily in reheat, in fact the second (re-heated) prototype did so on it's first flight quite unintentionally.  So you might want an engineer to give you the nod, but I'd say maybe, but probably only in a dive?
elmayerle
I'd go for a variation on the Swedish-built Avons (they seemed to get better afterburning performance than RR did) and I suspect she'd not be able to supercruise, though I suspect she could slip through the sound barrier in a dive without afterburner.  I don't believe any aircraft of that vintage was capable of supercruising in level flight on the engines then available.
--Jane Wagner and Lily Tomlin
Aircraft___Dry Thrust (lb)___Reheat Thrust (lb)___Max weight (kg)___thrust/weight ratio
Draken (late)_____12800_____________17600__________16000___________0.5
EE Lightning F6___13200_____________16300__________19000___________0.78
Hunter FGA9_____10150____________________________11000___________0.42
HA-300 (p. engine)_7500_____________10500___________5445___________0.87
HA-350 (whif)______9500_____________12000___________8000___________0.68
Arc3371
So you won´t be using the RM6C in the HA-350?
The point is the length of afterburners. Draken's and Lightning's afterburners are way too long for this airframe. I am thinking in an Avon downgraded version with a shorter afterburner (less than 2 metres).
Would it be possible?
Arc3371
elmayerle
Well, maybe.  I'd have to do some comparisons with other engines of the era (J79, especially since it's a very similar design - single-spool turbojet) to see what could be done there.  Just off the top of my head, I don't see any reason why you couldn't have a shorter afterburner section, but there may be some technological developments since then that I'm not aware of.
AeroplaneDriver
As you can see, tail pipe is slightly longer that in HA-300, so it can house an RR Avon and a small size afterburner.
Upper lip of nozzle does not contain a parachute but is part of airbrake, not yet installed.
Mike Wren
