Avia B35.d2
Started by wolfik, October 19, 2007, 06:14:59 AM
wolfik
hi all
here is my MPM vacu kit of the B.35 prototype.
it was a nice aircraft build by Avia before the war but the germans continued the work after the annexation of the Czechoslovakia (???).
I added the front of the old MPM Me109T kit which was desastrous and only the wings are "usable".
after some sanding its the "smoth transition" performed...
not sure about the tail planes because it will be a Finnish aircraft.
I tend towards the Me109 elevators instead the oryginal Avia parts....
but they are something bigger than the german ones...so my problem...
the idea was to make an aircraft build in licence by the finnish in cooperation with the germans thence the Me109 front with a more powerful engine.
in oryginal the wing was build from steel profiles and plywood covered with thin alluminum plates glued on it.so I was thinking its perfect for the Finnish   ^_^
some work was needed to make the undercarriage to replace the spats.
hope you like it
Peter
wolfik
wolfik
wolfik
wolfik
comparing to an ICM Spit.IX converted to a Vc
You replaced the spats?!!  :o
It's like drawing a moustache on the Mona Lisa!!!
*grumble* *grumble* *grumble*
Truly excellent work, even if it is spatless.
Deeply saddened,
