avatar_GTX
F-100 and F-107
Started by GTX, November 11, 2007, 01:26:10 AM
thundereagle1997
Sorry I thought the wing was the primary result of the Sabre Dance. Twin J-85-GE-21s would've made the F-100 a little better plus the wing & intakes of the Saab Draken as a modernised super sabre
Absolutely no need to apologise!  <_<
French F-100 with french touch :mellow: or, maybe, SMB2 on steroids.
thundereagle1997
Would an F-100 be better with side mounted intakes for excellent ground clearance a cranked arrow double delta wing for better low speed control a Rolls Royce turbofan to solve the sabre dance problem a bubble canopy for better visibility along with canard foreplanes twin vertical tails for better stability 4 30mm or 2 40mm cannons & a new array of air to air missiles would've made the Super Sabre even better?
Leading Observer
Quote from: thundereagle1997 on August 26, 2023, 03:18:22 AMWould an F-100 be better with side mounted intakes for excellent ground clearance a cranked arrow double delta wing for better low speed control a Rolls Royce turbofan to solve the sabre dance problem a bubble canopy for better visibility along with canard foreplanes twin vertical tails for better stability 4 30mm or 2 40mm cannons & a new array of air to air missiles would've made the Super Sabre even better?
Sounds like a Draken to me :wacko:
LO
It might be better, but it wouldn't be an F-100 any more, it'd be a totally new aircraft.
reddfoxx
Love the 100, and the 107 is one of my favorite planes.
Reading a history of the Pakistan Air Force, and they were offered the F-100.  Chose the 104, of course.  Also the F-80 earlier; I'll track down the P-80 thread.
