Avro CF-105 Arrow
Started by uk 75, April 26, 2005, 02:54:09 AM
No complaints from me ! I'm pretty sure it's the Yankee engine as per the prototypes.
Jeffry Fontaine
As Todd said, pretty much a good starting point for an Arrow, it has the overall shape and you just need to spend lots of time and money to get it right.  I have both releases of the 1/48th scale Hobbycraft CF-105 Arrow kit in protective custody.  Aside from the change in the way the wings were attached to the fuselage, it is pretty much the same kit complete with exhaust parts that have no real definition and at least in the later release the funny shaped fuel tank was deleted.
The missile shapes provided in the kit represent nothing in real life so you will need to source some AIM-7 Sparrow and AIM-4 Falcon shapes from another kit.  Let me know if you need any of these.  Other options to consider if you are going to WHIF-it would be to look at the AIM-47 and AIM-54 if you are interested in building an interceptor.
Good luck!
Daryl J.
#47
Chances this one will be built clean, thanks however.    Being tossed about the mix is a display where the weaponry is out front like often pictured by manufacturers; so there would be rocket/scramjet based air-to-ground strike capability.
One scenario:
Avro Arrow leaves Regina heading north to counter the stike on Minot AFB, drops a rocket with a scramjet nuke just inside Canada's northernmost airspace and begins a wide turn back to the Queen City whilst the rocket heads north over the pole,burns out, the scramjet zips into Russia.........k'blam.     Colors would still be White/Red/Black but some tribute markings to the prairie provinces in some way.  Scratchbuilt misselry
Or:  RAF used in conjunction with the TSR.2 and RN Vigilantes (see Jennings profile).
Or....Something USAF...
Or.... :thumbsup:  :thumbsup:
Daryl J.
Daryl J.
Additional external fuel tankage for starters, added bumps and barbs for electronic upgrades.
Daryl J., oh what might have been.
elmayerle
Mk.3 was supposed to have Fieri inlets and revised structure for higher speeds.  Mk.4 was, ISTR, the Mk.3 with underwing tank provisions.  Beyond that, there were studies of a high-speed/high-altitude version with an extended nose mounting canards and dual-ramjet/fuel pods under each with with the main gear retracting into them.
--Jane Wagner and Lily Tomlin
Archibald
This aircraft is my favorite of all times, but we already discussed it so much times (sigh...)
So what's new ?
Arrow with F-15 nose and engines (F-110 GE-129 of late Eagles) eventually F-15 intakes.
Arrow with F-6D, F-12 or F-14 AAMs (Eagle, Falcon or Phoenix). Anigrand Missileer could give its AAMs.
CEV Arrow (testbed for the Mirage IVB engines, the Iroquois was on the list but lost to the J-75 before the Mirage IVB itself was scrapped).
Raspberry ripple Arrow  :wub:
Scaled-down CF-105 with a pair of J-79 or Avon, no weapon bay.
Arrow with recessed AN-52, french nuclear bomber.
CF-105 with recessed Skybolt under the belly, SRAMs, or every cruise missile you can think about.
elmayerle
QuoteArrow with recessed AN-52, french nuclear bomber.
Strike Arrow proposal for the RAF included the capability to carry an advanced, scaled-dwon variatn of Blue Steel semi-submerged in the weapons bay.
I could see a recce pallet for the Arrow ith a modular eqipment fit like that fitted to some F-111s.
dy031101
#52
QuoteMk.4 was, ISTR, the Mk.3 with underwing tank provisions.  Beyond that, there were studies of a high-speed/high-altitude version with an extended nose mounting canards and dual-ramjet/fuel pods under each with with the main gear retracting into them.
According to "Avro Aircraft & Cold War Aviation" by Randall Whitcomb, Mk.4 was the low-cost alternative to the very-high-speed/high-altitude version (which was called Arrow PS-2) by combining Mk.3 airframe with the dual-ramjet/fuel pod.
EDIT: It's PS-2 not JS-2.  And I made the typo right after I read the book again...... how embarassing.
To-do list here
elmayerle
#53
I think the Mk.4 was not fully defined when the program was cancelled as I've also seen it depicted as I described; much the same configuration as was proposed to the RAF for a Javelin replacement.
I know Randall's picture (yes, I know him - take a look at the acknowledgements to Avro Aircraft and Cold War Aviation - my copy is autographed by both Rnadall and Jim Floyd and my copy of his "Thunder Before the Storm" print is autographed by him and Zura) but I've also seen the Mk.4 depicted by other artists as a Mk.3 with underwing tanks.
dragon
Anti-ship CF-105: fit it out with Exocet Missiles
Anti-Satellite CF-105
I don't know how maneuverable this beast would have been with canards....Maybe a "Wild Weasel" (or some other moniker- suitably Canadian of course) variant.
Maybe a "poor man's" SR-71 recon type?  Flat Black, of course!  B)
lenny100
I have a book which says that the whole program for the arrow was not cancelled but went black as a recon strike fighter and was its self replaced by the blackbird.
in the book it describes the aircraft as a single pilot with the rear cockpit replaced by a recon suite and panted dark green on top and sky blue undersides
QuoteBeyond that, there were studies of a high-speed/high-altitude version with an extended nose mounting canards and dual-ramjet/fuel pods under each with with the main gear retracting into them.
One of the original concept models of that:
Daryl J.
Respectfully said that concept uglified the aircraft significantly.  :ill:
Are there any handy links to other threads involving the Arrow.  I was unawares as to previous discussion.
FWIW, it would be fun to see a whiffed Arrow, TSR.2, and Vigilante all in the same squadron together.    B)
Daryl J., fascinated w/ the above info.
QuoteAre there any handy links to other threads involving the Arrow.
Just go to the 'search' button at the top and punch in arrow. Then surf through about a billion returns.  :P
You're right, it ain't pretty. But I would love to strap myself in and go balls to the wall!  :ar:
I was reading my Air-Britain book about the CC-106/CL-44 when I came across an interesting snippet of information.  It said that the CF-101 Voodoo purchase was connected to a sale of CL-44's to the States, this was to counter some Senator who had run a bill though congress that was to have prohibited any US airline from buying CL-44's (or other foreign airplanes for that matter but was aimed specifically at the CL-44) while US aircraft manufacturers were idle.  Apparently there was a lot of interest in the CL-44 from MATS at the time too.
Now for some reason I had thought that the CF-101 deal was connected to the Bomarc and the Arrow' demise.
Robert
