avatar_nev
F4U, AU1 (Vought), FG1, F2G (Goodyear), and F3A (Brewster) Corsair.
Started by nev, December 22, 2002, 12:11:09 AM
It looks like a Lincoln Merlin 85 set Kit, maybe a DB productions one (Flightpath).  It's not like Martin's set though or the Paragon Lancaster Merlin 85 set (which doesn't have the air intake positioned under the spinner)
D'oh! to late.  BTW Lincolns were powered by Merlin 85's -- however there was a Griffon 61 installation that did look a bit like it, on one of the Hawker Fury prototypes.
I wish I was at home, I have samples of both conveniently to hand, especially the Merlin 85s, for which I have two projects planned already.  ;)
It sure looks the business though.  :thumbsup:
The Griffon set-up that looks like that was used on another aircraft other than the Fury prototype, it was installed on the Fairey Firefly Mk.III.  Only one was built but later the Firefly AS.7 and U.8 also had the Griffon installed like that.  There's some excellent photos of them in the Squadron 'Firefly in Action' book. As far as I'm aware those are the only fighters that got that particular installation (someone is bound to jump in and correct me now --- )
nighthunter
Conversion makes good progress. Body work is through and I started painting - the EDSG/Sky livery with a high waterline looks excellent on the long-nosed Corsair. Decals are about to be applied  ;D
Radish
Sounds good....got a couple of 1/48th steampunked Corsairs.
One in Beer Wars "Budweiser" markings....the other is RAF in the Korean War. :thumbsup:
perttime
Quote from: Radish on October 30, 2012, 09:40:20 AM
What? Where? I want to see them!  :wacko:
perttime
.... an open cockpit corsair might look cool.
Then it would have to be built for a slightly earlier period, or some dieselpunk or even steampunk world ....
You could even make it a "Double Decker", with another (inverted) pair of wings on top of the front fuselage. Then add a fixed landing gear...? Sounds odd, but could work and even look good?  :unsure:
perttime
My feelings on biplanes are a bit divided but fixed landing gear sounds good  :lol:
The normal Corsair had a long nose which was bad enough, that one's ginormous!   Looks the part though!  Coming along nicely there.   :thumbsup:
Brutish, I like that!  Fighters don't have to be pretty, looks like it's been hit with the ugly stick, then turned it on it's owner and bludgeoned them to death with it. :wacko:
