avatar_Mossie
Folland Gnat WHIF Ideas
Started by Mossie, December 20, 2007, 03:24:27 AM
coolpop6307
Thread revive  ;D What about an attack version of it, kinda like the a-10's little brother.
"I am a tangerine, and no one can see me"
"Your despicable!!"
"EHHHH Whats up doc?"
coolpop6307
Here is a crude version of what I mean. Just put a 20mm vulcan up there and make it where it can carry to bombs ETC.
Thanks
  Joshua
"Your despicable!!"
I assume the pilot will be issued with Aspirin as standard?  ;D
Steel Penguin
or let the speed metal fans fly em, theyll enjoy the beat.
Hope there's a safety interlock between the gun-firing circuit and the ejection seat circuit..... :o
coolpop6307
Quote from: rickshaw on September 14, 2012, 06:38:28 PM
Yes most likely he would need two... ahh heck just give a bottle  :lol:
Quote from: Weaver on September 15, 2012, 09:17:36 AM
I think the ejection would end up firing down instead of up because if you look the gun is in the way.
"Your despicable!!"
IMHO the gun unit would be hinged at the rear so that when the seat went up, it was attached to the front of the gun unit, so the gun unit would be saved in the ejection along with the pilot. This is recycling at it's best. Simples  :rolleyes:
Quote from: coolpop6307 on September 16, 2012, 06:02:35 AM
One  acoustically treated asprin for each ear, perhaps?
A slighty less headache-inducing fit would be an Oerlikon KCA (or Mauser BK-27 perhaps) in a centreline mount? Coupled with a pair of Matra rocket pods underwing.
coolpop6307
Other than the ground attack gnat, what about a drone one?
  Thanks
    Joshua
"Your despicable!!"
There's a proposed gun pack that Aircav posted on page 2.  They had two Browning .50's in a converted slipper tank.  I guess you could substitute a single cannon for the pair of MG's, giving two in total.  Or you could have an assymetric load, cannon on one wing, slipper tank on the other?
Quote from: Mossie on September 18, 2012, 02:01:45 AM
And an enlarged rudder presumably?  :wacko:
There's a DEFA pod with a 30mm cannon , but it might be a bit on the long side for a Gnat. One thing that might work would be to hang a cannon on each inner pylon and an ammo box on each outer pylon (all in aerodynamic pods, of course), with an aerodynamically faired ammo feed between the two.
It'd make re-arming quicker but the load is a bit small on the gnat for it to be an effective ground attack aircraft.
Might work if you based it on later marks, they would have been able to carry more.  The Finnish Gnats had a couple of extra pylons IIRC and the HAL Ajeet could operate in the ground pounding role.  The load was light, but not a lot less than other aircraft of the era and not bad for COIN ops.
http://www.bharat-rakshak.com/IAF/Images/Vintage/Fighters/Ajeet/Ajeet_Armt.jpg.html
You could always fit longer wings.......  ;D
