avatar_Radish
F-18 and F-17 Hornet
Started by Radish, January 20, 2004, 01:04:14 PM
Yeah - my favorite wing/tail combination!  :thumbsup:
Another thing you could do is extend the booms beyond the trailing edge of the upper fins, mount the lower fins behind the upper ones, and have the end of the boom rotate through 180 deg to get them clear for landing. That would avoid any stores/flaps clearance issues with sideways folding fins.
KJ_Lesnick
I think it would be more practical to use the regular F/A-18 tailfin set-up...  the current tailfin gets in the way of the wing-folding which is necessary to operate on carriers...
KJ Lesnick
Shasper
Just remove the angle from the verts & it'll be ok!
Shas b)
- Bud S.
KJ_Lesnick
Shasper, some folding wings fold more than 90-degrees.  Unless the tailfins canted inwards it wouldn't work.
Regardless, the tails as they are work just fine at high alphas...
Jeffry Fontaine
#49
How about an F-18 with the wings from the F-15?
MDD did produce some conceptual artwork of an F-15 with an F-18 style wing as a proposed improvement several years ago.
KJ_Lesnick
Jeff,
Sounds like an interesting idea.
Another idea I'm fond of would be adding the booms on the F-16 (they're on either side of the fuselage aft of the wing all the way to the tail and mount the speed brakes and horizontal stab) to the F-18
KJ Lesnick
dy031101
A simple exercise of fitting the F/A-18E with canards, courtesy of Konami and their Airforce Delta Storm for the first XboX......
The aircraft is named Airacobra II in the game......
To-do list here
rallymodeller
McDD's idea for the Super Hornet, as shown in the Aerofax F/A-18 book, is sort of like a cross between a Hornet and a Gripen -- rear mounted delta wings with upwardly-canted canards in place of the LERX. If my scanner was working (grrr) I'd scan it in for all to see.
I'll see if I can find pix online.
--Jeremy
Sauragnmon
Very neat stuff, and I look forward to seeing that Delta Superbug, Rally.  Should be very interesting.
TsrJoe
http://www.whatifmodelers.com/index.php/topic,18207.msg304969/highlight,aggressor.html#msg304969
just found out from an Ilmavoimat pilot at Kauhava that the Hornet i surmised was in a possible 'aggressor' scheme' was in actuality 'photoshopped' to appear dark emphasising an enemy type in the footage, bummer!  :banghead:
ah well, i stil fancy modelling it as a 'what if' anyway
cheers, Joe  :thumbsup:
Jschmus
Chris707
One wonders if there would be a single major part in common...nah...
"Ultrabug"... kinda like the sound of that....
Those CFTs are rather subtle, aren't they? They stand out like the dog's danglies on the F-16s, but it took a second glance to see them on the Rhino.
Is that a "stealthy" drop tank? Neat idea!  :thumbsup: Wonder if it could be coupled with the stealthy AAM carriage on the Silent Eagle? A somewhat "stealthy" way of carrying AAMs and fuel!
Shasper
#59
CA, I think thats a stealthy weapons pod. . . Read somewhere that Boeing was looking into that.
  Taking a look at the artwork, I wonder if they'll refit the dogtooth from the Growler?At anyrate, I'm thankful that they're going with the IRST mounted under the nose ala F-14, that whole bit about sticking it on the front of a droptank was crappy in the first place!
- Bud S.
