avatar_Archibald
Gloster F5/34
Started by Archibald, December 31, 2007, 12:55:44 AM
Archibald
#30
QuoteHow about an upgraded version with something like a Bristol Hercules engine?
Well, why not trying Taurus ?
QuoteDiameters are close, the biggest differences would be in overall installed length and a major increase in weight.
Mercury around 1,095 lbs
Hercules around 1,845 lbs
Taurus was 1300 Ib dry
Taurus is also smaller:
Diameter: 46.25"
Length: 49.2"
Maximum power rating:
max boost setting of 4.25 lb/ sq inch, 1,140 bhp at 3,225 rpm from takeoff to 1,000' or one minute. All-out level flight for same settings is five minutes. 87 Octane fuel.
Figures from Lumsden 'British Aero Engines'.
Jon
Archibald
So let's try the Perseus.
The -XA variant of the Botha was rated at 930 hp against 840 hp for the Mercury. This would be an interim engine, then switch to the Taurus when available.
the Perseus was not much used aside the Botha, an aircraft nobody would regret after its cancellation circa 1940...
QuoteThe Gloster F5 prototypes *may* have been as fast as the Hurricane, but not once you've added such operational extras such as radios, IFF, armour, guns, etc.  The engine itself wasn't suited to fighters and virtually all of the fighter types that used the Mercury were hacked out of the sky by the Luftwaffe.
Well then the RAF could have used it as a British Tunderbolt! Boom and zoom :P
