avatar_gooberliberation
P-47 Thunderbolt ideas.
Started by gooberliberation, January 26, 2008, 02:39:31 PM
Sort of related:
I've long had an idea for an attack aircraft that looks like a Fokker G1 on steroids, with a P-47 powertrain in each boom, a high tailplane and a thumping great recoilless (Davis-type) gun in the lower fuselage. Because the Davis gun uses a counter-weight rather than counter-blast, there'd be no blast-damage effects on the boom or tail - just do NOT fly behind on on a straffing run unless you fancy several pounds of grease and ball bearings in the kisser....
It would be to the P-38 Lightning what the P-47 is to the Mustang...... :wacko:
Something silly:
Aircav
Sir Sydney Camm
Vertical Airscrew SIG Leader
What if when the Cavalier Turbo Mustang III was proposed, a similar turboprop P-47 was also offered:
Please note that the engine is entirely fictional, though I did use the T-56 as inspiration.  Note also that the turboprop exhaust is via the similar P-47 turbocharger ducting/exhaust
Daryl J.
P-47N COIN tuned for low altitude work.    If life weren't so upended for us right now, there'd be one of these in the GB going up.
Daryl J.
ElectrikBlue
Very insteresting, really like your turboprop P-47 profile Greg!  :wub: :thumbsup: :bow:
EB
Jeffry Fontaine
Has anyone attempted to create a 20mm cannon armed P-47 by replacing the eight machine guns with four Oerlikon or Hispano-Suiza cannons?
Quote from: Jeffry Fontaine on July 05, 2009, 07:06:40 PM
This is actually an idea I want to materialize.
Doc Yo
 I went looking for a review of the MPM XP-47H, and found this instead:
http://modelingmadness.com/reviews/allies/us/usn/ran47h.htm
A whif for sure, and nicely done, too. Really have to build mine one of these days, but I keep thinking
about trying to convert it to a bubbletop...
Quote from: Doc Yo on July 21, 2010, 09:38:20 AM
It's not too bad for a limited run injection.  There's no line up pins for the parts so a little care is needed when glueing the bits together. I think I used an aftermarket white metal prop though, the kit one didn't seem big enough in diameter and I used a True Details P-47 cockpit set too. I also used some white metal u/c legs which I got from High Planes, the plastic is very heavy as all the parts are at least twice as thick as any other injected kit and the original in u/c legs looked a little suspect.
dy031101
The various P-47 models and derivatives have seen the adaptation of interesting wing designs- some with powerful armaments (like 37mm cannons), others with built-in fuel tanks, and such......
What would have been produced if given the "Supermarine Attacker" treatment, I wonder?
To-do list here
And all I did was put it in some markings it should have flown in.
Then, maybe, there wouldn't have been so many (Mustangs) lost to ground fire.
Pablo1965
Quote from: philp on July 21, 2010, 03:32:22 PM
Agreed :thumbsup:
Pablo1965
Quote from: kitnut617 on July 21, 2010, 02:47:20 PM
This is my weakness..I love the plane.
Uploaded with ImageShack.us
I'm going to do something similar to that, but I'll be using a nacelle from a B-50/C-97 for the conversion. I've also thought about doing a Sabre-powered version. Got a couple of the very nice little Revell kits in the stash. :)
